wheel hop |
wheel hop |
Apr 28, 2004 - 10:35 PM |
Enthusiast Joined Feb 15, '04 From saskatoon, sk Currently Offline Reputation: 0 (0%) |
Is it just me or do these cars get an obscene amount of wheel hop.
if i launch and get the tires spinning the car hops. i find it very hard to race because of this. every single time i spin the tires the car hops like a mofo. what could be the problem and how do i fix it? |
Apr 28, 2004 - 10:39 PM |
Enthusiast Joined Apr 3, '03 From Omaha, Ne Currently Offline Reputation: 0 (0%) |
If you are racing, and getting that much tire spin then you must be revving really high. I never get wheel hop. Mabey you should check your tires. Could be over inflated.
Apr 29, 2004 - 10:23 PM |
Enthusiast Joined Jan 8, '03 From Miami, FL Currently Offline Reputation: 0 (0%) |
get a 3sgte and then complain of wheel hop... my **** does it like crazy, even without launching.... bad springs or shock absorbers i suppose... just upgrade your suspension and you should be fine
Mina |
Apr 30, 2004 - 9:38 PM |
not revving high at all rev it to 1200 and get wheel hop |
May 1, 2004 - 12:07 AM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
You're revving it to low, hahahaha.
I used to have the same experience with my 95. Personally, with good tires, i got a great start with 4500, i'm sure i could've fine tuned myself a little bit more, but i never got the chance....dang guy ran me into a median. -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 1, 2004 - 9:45 AM |
Your suspsension sucks...get a better suspension.
May 4, 2004 - 12:10 AM |
serious? rev to low? |
May 4, 2004 - 3:58 PM |
That's what i think, everyonce in a while, i don't mean to get a race start (like at a stop light all by my self), and i really wanted to just go forward, haha. So that means my rpm's were around 2500 or so, and i get wheel hop. What are your rpms when you get your wheel hop?
May 7, 2004 - 11:08 PM |
Enthusiast Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
i can take off at around 3000 and i get no wheel hop.... get better tires and suspension
May 9, 2004 - 7:47 PM |
hops at about 1200 and above |
May 9, 2004 - 10:43 PM |
try a 3500 start.
May 9, 2004 - 10:44 PM |
and also, tell me exactly what you do, like after you dump the clutch, do you slam the gas down, and stuff like that.
May 10, 2004 - 9:59 PM |
yes and no ive tried both putting it down and not puttin it down. oh and when its raining, no wheel hop. foound that out the fun way |
May 11, 2004 - 8:09 AM |
Well, the rain is common smartz, haha. Less friction. I would say hyping your rpm's up some more when you get off the line, that should get rid of the low rpm wheel hop, if you're putting more power to the wheels at once, then it also creates less friction, and then of course cetchs, you're at a high rpm, and you're off!!
May 11, 2004 - 8:18 AM |
Enthusiast Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
What physics class did you take? That doesn't make any sense at all. |
May 11, 2004 - 11:13 PM |
i didn't read it after i wrote it, sorry, haha. I should've said, if you put more power to the wheels at once, and create spin, the friction is lost. But, it will come back, and that's your start. Does that make more sence. I think i might be confusing my self, but i'm sure he gets the idea
May 12, 2004 - 8:39 PM |
yeah i got the idea. i tried launching at 3000 and the tires spun but no wheel hop. the only thing is its quicker not launching because i get too much spin
May 12, 2004 - 8:46 PM |
just kinda play with the launches and how much gas you put in after you launch
May 12, 2004 - 8:48 PM |
i also forgot to tell you, if you're racing, or just want to play around even more, let a little air out of your front tires.
May 12, 2004 - 9:56 PM |
let air out of your tires = step one
rev up to around 2000 rpm with the clutch out far enough that its grabbing and you let out anymore your goin to move= step two light turns green dump the clutch hit the gas you might even do this at a lil lower maybe not sure yet = step 3 |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:15 AM |
