> rear disc conversion Q?, quick question..
post Apr 28, 2004 - 10:38 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
if i purchase a loaded calipar from cardone, they come with the torque member, aka mounting bracked, along with these ill need new ebrake cables and rotors correct? what else is needed to do this mod.
post Apr 29, 2004 - 12:03 AM
FallenHero
Joined Dec 26, '02
From Alabama
GT brake lines
post Apr 29, 2004 - 5:45 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (FallenHero @ Apr 28, 2004 - 10:03 PM)
GT brake lines
are they the molded hard lines? or the ebrake lines were talking about?
post Apr 29, 2004 - 6:21 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
the brake lines for the fluid, not the ebrake
post Apr 29, 2004 - 6:50 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (Jeremy1210 @ Apr 29, 2004 - 4:21 PM)
the short lines? lol, im putting too thought into this.
post Apr 29, 2004 - 7:01 PM
SpedToe169
From Dallas, Tx
They're like 12 or 16 inches long with a 10mm banjo fitting on one end and a reverse flare fitting on the other.
post Apr 29, 2004 - 11:59 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (SpedToe169 @ Apr 29, 2004 - 5:01 PM)
thanks!! im sure it has been described before, but what is the difference in the front brakes in the ST and GT? will the SSlines for the GT work on the ST's front?
post Apr 30, 2004 - 12:40 AM
SpedToe169
From Dallas, Tx
Yeah, the lines should be the same on the ST and GT. The GT brakes are just a little bigger. The calipers are also slightly different, they require different pads.
post Apr 30, 2004 - 6:41 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
to thoes who have done the conversion, how much $ did you have to put in it?
post Apr 30, 2004 - 8:13 AM
SpedToe169
From Dallas, Tx
Brake Parts: $170
Pads: $35 (did the fronts at the same time +$35 more, also did front rotors +$100)
Bushing that I ruined trying to get it apart: $25
Mine too forever to do becase everything on my car was rusted and seized up. Make sure you get all the spindle bolts and other hardware off the donor car in case you need to cut stuff off like I did.
post Apr 30, 2004 - 8:38 AM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
$300 shipped, the stuff was in great condition, everything went smooth. it took me about 3 hours.
post Apr 30, 2004 - 9:35 AM
FallenHero
Joined Dec 26, '02
From Alabama
So far I have spent $115. I have the whole assembly from both sides unbolted and removed, and I have the brake lines and E-brake lines.
Lo-Fi Version Time is now: February 17th, 2025 - 2:21 PM
