> Antilock Brakeing System
post May 1, 2004 - 2:57 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
I saw that in the engine bay there is a relay box and in it are 2 open places for 2 relays. One is for the Abs Motor and the other is for the Abs Solenoid, at least i think so they sayABS SOL and ABS MTR, so thats what i figured they meant. I was wondering if there is a motor that you can get for abs because there have been times where i wished i had abs.
My car = 0-60 in ~9sec
It's slow, I know
post May 1, 2004 - 6:51 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Installing ABS into a car without it is not cost-effective, and can be potentially dangerous if the system is not installed properly, imo. You need to essentially swap the complete braking system from the donor car to your car.
I suppose it could be done, but I have never seen anyone actually do it.
Heh, just found a link to an ABS installation. It's a Miata, but should still give you some idea of the time and complexity.
http://www.miata.net/garage/abs/abs.htm
post May 3, 2004 - 4:38 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
off topic but I remember seeing a lot of ABS hate on these forums when I was searching
why?
post May 3, 2004 - 5:41 PM
Hanyo
Joined Aug 16, '03
From Bay area
i remember reading an article about how BMW didnt install abs on one of there sports cars because people tend to think there brakes are not working when they first stomp on there brakes, so they end up lifting there foot off and reapplying the brakes. this renders the abs useless.
post May 3, 2004 - 8:08 PM
i have abs. i can really say that it saved my but one time. i was taking an off ramp that i never took before and didnt know that the turn was going to be so sharp, i slamed on the brakes and abs kicked in and helped the car not loose traction through the turn. other then that time it will come on once in a while if its raining or snowing out. so, all in all its a nice thing to have, but i dont think its worth trying to install aftermarket because you just dont get that much use out of it.
post May 3, 2004 - 10:20 PM
macavely
Joined Nov 4, '02
well on the road the leads into the parking lot of my job.. i just tested out my abs... and i have to say it worked really well.... i never been in a situation(sp) were i had the need for ABS but its nice to know i have that option now..
oh and it's been rainning all day today.. and the roads are nice and wet with lots of puddles ..
Lo-Fi Version Time is now: April 24th, 2025 - 3:32 PM
