> Front and Rear Sway Bars, question for those that have them
post May 1, 2004 - 10:42 PM
jgreening
Joined Jan 17, '04
From Illinois
I am considering upgrading to the Suspension Techniques sway bars. For those that have them, what are the performance gains versus how much they make the ride punishing. I am trying to strike a balance between improved handling and ride comfort. To illustrate this these are the mods I have chosen (so far):
Performance enhancing:
TRD Springs
Front Strut Tower Brace
Side tower braces
Ride comfort:
KYB GR2
16" wheels (with 4 inch sidewalls)
post May 1, 2004 - 11:01 PM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
I don't think that they make the ride any different, they just make the car handle better in cornering
post May 2, 2004 - 5:27 PM
They didn't affect my ride quality at all, but I can handle a lot better in corners now. The car has much less body roll. smile.gif
post May 2, 2004 - 9:04 PM
jgreening
Joined Jan 17, '04
From Illinois
post May 10, 2004 - 9:33 PM
keefer37
Joined May 10, '04
From Durham, NC
I'm new to the mod world.. I've got a stock '96 Celica ST 25th Anniv. Where in the line of mods should the sway bars be added? Is TRD the way to go with this upgrade?
post May 11, 2004 - 12:28 PM
98celica3
Joined Aug 30, '02
From North Carolina
QUOTE (keefer37 @ May 10, 2004 - 7:33 PM)
swabars really help cornering. As far as i know Suspension techniques is the only company that makes sway bars for our cars. as far as when or where in the line you should do sway bars, my suggestion would be anytime after you lower your car.
adam
This post has been edited by 98celica3: May 11, 2004 - 12:29 PM
MISS THE CELI, BUT...
post May 11, 2004 - 1:35 PM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
A larger front bar will tighten up the front and allow you to transition faster; however, you are also going to pay for it in a long corner, as your (now) tight front end will be more likely to push out.
Depends on what you want to do with the car. I have the Suspension Techniques front on my car, but am going to switch to the stock ST front bar (19mm vs. 20mm for the stock GT bar), because I spend more time actually in corner than I do turning into it.
post May 11, 2004 - 2:11 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I just bought the st sway bars front and rear..
do they come with the swaybar links ?
This post has been edited by defgeph: May 11, 2004 - 2:12 PM
I will return one day.
post May 11, 2004 - 2:14 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
QUOTE (defgeph @ May 11, 2004 - 7:11 PM)
The rear bar I bought from ST did not come with new end links. I wouldn't expect to see any in the full kit either.
post May 11, 2004 - 2:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
ok thanks scm, I'm just asking cause in the pic it had the links. so I was just wondering. Look like I'll be going to toyota when I get them
post May 11, 2004 - 3:31 PM
uzthedentist
Joined Mar 21, '04
From united kingdom
If you wat to help cornering then stiffen the rear up first by anti roll and strut bars and then afterwards stiffen up the front
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post May 11, 2004 - 5:09 PM
TTE
Joined May 19, '03
From NJ
Defgeph they come only with bushings you dont need anything else
post May 11, 2004 - 6:17 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
ahh thanks my friend
DEFq
post May 11, 2004 - 11:44 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
Do all 6gc's come with stock sway bars?
post May 12, 2004 - 9:31 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
AFAIK all celicas have F/R sway bars stock
post May 18, 2004 - 1:59 AM
97GTinKC
From KC
QUOTE (Jeremy1210 @ May 12, 2004 - 7:31 AM)
They all had sway bars stock, there is another post somewhere with stock part numbers, but basically, 96 and newer GT had the stiffest stock bars, all years end links are the same, so for an inexpensive upgrade, you should be able to use the later rear stock bars on a 94-95 if you use the later frame bushings. (the 94-95 Sport suspension package rear bars are the same part no as the stock later GT bars. ) Front GT bars are 20MM dia, I believe ST bars are 19MM? (I hope that makes sense)
heres the post with part numbers: post
What I would like to know, is whether anyone with a 96 or newer GT has installed the Suspension Techniques bars and how much did they improve handling?
This post has been edited by 97GTinKC: May 18, 2004 - 2:11 AM
post May 18, 2004 - 2:16 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
my st are coming this week
so when i put them on i will post on how they feel
This post has been edited by defgeph: May 18, 2004 - 2:16 AM
post May 25, 2004 - 4:36 AM
xeril
Joined May 24, '04
From state of northern virginia
i have a 5th gen celica, but i have the whiteline sway bars. they are really nice. for the 6th gen celica, they appear to have 22mm front, 20mm rear. possibly other sizes, i didn't check very in depth. for my car, i got 27mm front, adjustable 20-23mm rear. i like a lot!
This post has been edited by xeril: May 25, 2004 - 4:38 AM
post May 25, 2004 - 8:18 PM
jgreening
Joined Jan 17, '04
From Illinois
I installed my Suspension Techniques front and rear swaybars today. I haven't driven much yet but I can tell the change is pronounced for cornering.
I do have another question though for others who have installed them. I get a hard rubbing sound from the sway bars when I hit bumps. Anyone else have this issue? Did it go away once they were broken in a bit? I am wondering whether they need to be lubed or adjusted in some way.
This post has been edited by jgreening: May 25, 2004 - 9:15 PM
post May 25, 2004 - 11:22 PM
FallenHero
Joined Dec 26, '02
From Alabama
you should probably lube the mountings.
Lo-Fi Version Time is now: January 9th, 2025 - 8:04 AM
