> windshield wipers
post May 2, 2004 - 12:45 AM
celicarocker
Joined Sep 25, '03
From cranston RI
ok my windshield wipers dont work... they did earlier.....
now.... the only thing i can think of, is (a little background story): i removed my winshield washer fluid resivoir becuase it was cracked to ****. so on the bottom, i had to pull out what im assuming is the pump for it, cuz it has wires coming off and stuff. so i just tuck that up. well im driving along today, and it drops down and smacks my tire a few times, and like cracks in half (ill post a pic tomorrow). so i just figured "screw it, the pumps broken, i just wont have washer fluid. so i tuck both ends up good this time and take off. later i try turning on my wipers, they dont work... will severing the connection on that thing cause them to stop? dont see why... and if so, can i just take the wires and connect them together and bypass the pump thing?
post May 2, 2004 - 6:49 AM
3TST
Joined Sep 27, '02
From UK
Wiring and circuits are a pig!
I would guess that the pump forms part of the windsheild wipers circuit and by disconnecting the pump you have broken the circuit and nothing works.
Think about, when you squirt the fluid, the wipers work automatically.
Hence the assumption above.
Try connecting just the pump up again (independant of/not in the resevoir) and see if the windsheild wipers work.
If this works, find a safe place to put the pump and fix/zip tie it.
post May 2, 2004 - 9:35 AM
celicarocker
Joined Sep 25, '03
From cranston RI
QUOTE (3TST @ May 2, 2004 - 7:49 AM)
i thought about that last night after i made the post.... gonna try to fix it today, it looks like its gonna rain frown.gif
post May 2, 2004 - 12:12 PM
celicarocker
Joined Sep 25, '03
From cranston RI
ok, i snapped some photos....
this is what i have to work with. the part on the left is the actuall pump, and the part on the right is the plug. it just to have a round piece on the top so it could connect all nice-nice...
the actuall pump part. me thinks since its empty inside, there once was something that was in there to make the pump actually work. but not anymore...
the plug... like i said, it had a black round piece at top so it would seal the pump, but not anymore... i know i cant fix the pump itself the way it is (im going to buy a new one...) but can i connect some of those wires to complete the circut so i can just use my windshield wipers again? one is blue with a red stripe, one is blue with an orange stripe, and one is blue with no stripe...
post May 2, 2004 - 12:29 PM
celicarocker
Joined Sep 25, '03
From cranston RI
well, i did what you should do when any electrical thing doesnt work...
i checked the fuse... blown... replaced that, they work now.... when the pump busted, it must have blown the fuse somehow...
Lo-Fi Version Time is now: February 25th, 2025 - 1:15 PM
