> Rolling my fenders, need some advice
post May 3, 2004 - 9:21 PM
98celica3
Joined Aug 30, '02
From North Carolina
With my new 18's on, my wheel spacers, and my coil-overs, when i hit a bump my tires rub the lip on my rear fenders. I want to role that little lip, but don't want to bend the fender. How can i do this? i don't want to get rid of the spacers, or raise the car.
adam
MISS THE CELI, BUT...
post May 3, 2004 - 10:19 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Jack the car up and use a baseball bat. Roll the bat with a little pressure,too much pressure will be bad.
This post has been edited by 95STHATCH: May 3, 2004 - 10:21 PM
post May 4, 2004 - 12:24 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
When I get back to work, I got a article there on how to do it. I will scan it and send it to you. I believe it also said to heat up the fender with a heat gun so the paint does not chip.
post May 4, 2004 - 8:56 AM
98celica3
Joined Aug 30, '02
From North Carolina
QUOTE (madmods @ May 3, 2004 - 10:24 PM)
That would be great. thanks.
adam
post May 4, 2004 - 9:07 AM
Junior
Joined May 5, '03
From Toronto
I noticed that in your profile you didn't list any upgrades to your struts. I would suggest getting a some stiffers shocks like koni's. Also the spring rate on the drop zone coilovers is pretty low. You'll bounce a lot, the stiffer suspension will help a lot. To roll your fenders you need to make some cuts every inch on the inside of the fender. Then take a torch and heat it up, do heat it up till its red, just enough so it'll bend easier with out the paint peeling. While the fender is hot, bang it out with a rubber mallet. After you're done, i'd tape up the car and spray the inside of the fender with paint to prevent rust from all the cuts you made.
post May 4, 2004 - 10:25 PM
phat94celi
Joined Oct 9, '02
From Longmont, CO
I just read something earlier today on that. It was about using a baseball bat. I'll see if I can find the article.
post May 5, 2004 - 9:32 AM
phat94celi
Joined Oct 9, '02
From Longmont, CO
Heres the LINK
post May 5, 2004 - 10:04 AM
Junior
Joined May 5, '03
From Toronto
in that last shot, the fender looks a little warped.
post May 8, 2004 - 3:54 PM
98celica3
Joined Aug 30, '02
From North Carolina
I just took a saw and made little cuts in the inside of the fender every couple of inches for about 18-20 inches. Then i heated the fender up with a hair dryer and beat it back with a rubber hammer biggrin.gif then i of course primed and re-painted it. Looks good and i don't rub anymore.
adam
post May 8, 2004 - 4:03 PM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (phat94celi @ May 5, 2004 - 8:32 AM)
Heres the LINK
holy.... i just laughed so hard because like out of nowhere comes his special fender rolling too
i am awesome
Lo-Fi Version Time is now: December 4th, 2024 - 4:14 PM
