> Shaving Spoiler
post May 5, 2004 - 8:31 PM
moltar
Joined Mar 31, '04
From Cincinnati, OH
Planning on shaving the spoiler, but before I do - has anyone found a way to get rid of the holes? I'm open to ideas! And no, I'm not using duct tape. smile.gif
post May 5, 2004 - 8:32 PM
celicarocker
Joined Sep 25, '03
From cranston RI
bondo
post May 5, 2004 - 8:42 PM
moltar
Joined Mar 31, '04
From Cincinnati, OH
QUOTE (celicarocker @ May 5, 2004 - 9:32 PM)
bondo
Will it look okay? I don't want it to look like I should have a primered bodykit bolted on too! wink.gif
post May 5, 2004 - 9:13 PM
celicarocker
Joined Sep 25, '03
From cranston RI
slap some bondo on, then sand it down till its smooth.... no matter what you'll have to have the area painted over...
post May 5, 2004 - 9:19 PM
moltar
Joined Mar 31, '04
From Cincinnati, OH
post May 7, 2004 - 12:00 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
what yah do if yah dont want to paint and barly anyone well notice is take some interior plugs the black ones that have a flat top and lots of little grippers and shove it in there it should work seen it done on a turbo si civic that i show with/ well next week offcouse take some paint and math it to best you can the plugs
This post has been edited by pxcr440: May 7, 2004 - 12:00 AM
post May 7, 2004 - 10:27 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
won't bondo crank cause there isn't anything under it to hold it??
i had to have mine welded over, then bondo'ed smooth.
i heard u can use clear exterior silicone.
put a piece of tape over the hole, squirt some silicone inside from underneath, let dry, take tape off and bondo.
Jared Harwell
post May 8, 2004 - 3:45 PM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
use fiberglass cloth or mat and resin. Let it dry, sand w/ light sand paper, clean w/ laquer thinner then place very thin even coat of bondo over. let it dry sand down, and if needed do second very thin even coat and sand down until completely smooth and even. Then clean again w/ laquer thinner, spray primer. and after use primer sealant so rust won't get under paint.
Lo-Fi Version Time is now: December 12th, 2024 - 2:50 PM
