> Touch up Paint, kinda dumb question, but hey....
post May 6, 2004 - 3:40 AM
acenova
Joined Dec 21, '03
From Portland, OR
Alright, I just want to be sure on how to do this before I go and buy the touch up paint from the dealer. I have a lot of knicks on my hood and a few spots on my car that I want to touch up and blend in w/ the rest of the car. My hood is getting freckles. I have a white car, and just wanted to know how to do touch up? Do I have to sand over the spots I want to touch up??? SHould I wax the car first to see how bad the knicks are??? I don't know, gimme some pointers for touch up. biggrin.gif
post May 6, 2004 - 4:14 AM
neoklis
Joined Oct 24, '03
From Cyprus
Clean it up
use the touch up paint
wait 24hrs to dry
wax it smooth
post May 6, 2004 - 5:29 AM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
Get all the wax off the part that you want to touch up, primer it and then add the touch up on in thin layers, not one big blob. Don't use the brush that comes with the touch up paint. Its better to use the end of a toothpick.
post May 6, 2004 - 7:26 AM
blkGT
Joined Jun 10, '03
From FL
QUOTE (SiKBOY @ May 6, 2004 - 3:29 AM)
hes exactly right, take a toothpick and use the smalled amount at a time possible. let it dry and repeat. the more small thin layers you have the better it will turnout.
post May 6, 2004 - 7:30 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Well **** I had read this earlier, I just applied black touch up paint.
- Ryan
aim: rkgreen04
post May 6, 2004 - 7:43 AM
i applied some a few months ago and used the brush. it didnt end up looking smooth at all. anyone know if that can be fixed with a buffer or something?
post May 6, 2004 - 2:52 PM
Shortty
Joined Jan 28, '04
From Mids
using a fine wet'n'dry, sand off the bump of the touched up paint, be very carefull with this bit, it will sand down easily, and dont scratch any of the normal paint (use a small rubbing block)
Then use an abrasive polish to blend it a bit before giving it a t-cut and polish/wax.
HTH
Shortty
post May 7, 2004 - 4:38 AM
neoklis
Joined Oct 24, '03
From Cyprus
When i have such issues i put masking tape around the touch up paint and wax/polish it until its smooth. The masking tape protects the original paint job.
post May 7, 2004 - 11:32 AM
saleeka
Joined Sep 4, '03
From Twin Cities MN
if your having problems, you should prolly just buy new touch up... i did a couple months ago since my old stuff came from when the car was new and my resuts came out perfect...
post May 7, 2004 - 11:45 AM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
I was gonna touch up some spots on my car, but when I took the lid off the paint bottle paint shot all over my car. Had to wet sand it off. frown.gif Just be careful and make sure you match the color. Clean it, primer, and then touch up.
Lo-Fi Version Time is now: November 24th, 2024 - 8:04 AM
