![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
AND I SEARCHED
Do any members have these installed and painted. I just want to know if they accommodate the side markers. thanks. |
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) ![]() |
sapperk and nik have pictures of them on their cars in their profiles
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
check out player158 's profile
-------------------- ![]() I will return one day. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
as far as I know there aren't exisiting holes for the sidemarkers. you could however cut the hole out yourself or better yet leave the sidemarkers off.
Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) ![]() |
There isn't a hole but there are GROOVES or INDENTATIONS in the Fenders exterior part which sucks if you don't put sidemarkers on. You probably have to fill it if you don't want to indentation or it is really easy to cut out.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
i didnt want the side marker lights so i smoothed them over
-------------------- yea your 3sgte is cool but ill stick to my 7agte
the identations is easy to cut out with a dremel thats what i did, and your biggest worry won't be that, it will be getting the stupid things to fit right, i had to heat gun it a bit, the bracket that attached the fender to the body on the inside of the fender by the door is what you have to heat up
Enthusiast ![]() ![]() Joined Jul 8, '03 From Dallas, TX Currently Offline Reputation: 0 (0%) ![]() |
do the outlets on the Z3 fenders help performance as it can let out some of the hot air
![]() Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) ![]() |
As far as I can tell, no. If I remember correctly, the area of the fender that is vented is completely separated from the engine bay, and I'm certain you'd get no brake cooling improvements. If I'm wrong about either, someone please let me know. as it's been quite some time since I've removed my fender. I don't like 'em, but each to his own. |
Lo-Fi Version | Time is now: February 18th, 2025 - 6:33 PM |
