![]() Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) ![]() |
What should i use to clean my turbocharger.. Its a little dirty and has oil on it... I would like to clean it up real nice be4 i use it... Does anyone suggest nething???? And is it safe to get it into the shaft??.. Like will i be able to clean the whole turbo or just the housings?? Thanks
![]() Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) ![]() |
Use the good ol' brake clean. That stuff will eat anything and just evaporates. I think it might be safe to use but you should probably get a second opinion.
thank you and ne 1 else?? cmon someone must know..... Some1 told me Simple Green, but i have no idea..
Also there is already a layer on there to prevent rust.. So what can I use just to clean it up a little, from the gunk and oil but not hurt the turbo or get the fear that it will make it rust.. i know i cant use water because that will cause rust.. So Some1 must know ![]() This post has been edited by hyp3rk1d: May 8, 2004 - 5:24 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
I know the auto shop my friend works at uses Simple Green alot...i think it might just be for degreasing of external parts though. I wouldnt run it all inside the turbo or anything, but cleaning the surface with it would be fine. Brake cleaner also does a great job with degreasing anything, so i would opt to use that first. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Lo-Fi Version | Time is now: February 16th, 2025 - 8:39 AM |
