94-97 koni yellows, will they fit a 98 gt convertable? |
May 8, 2004 - 4:04 PM |
Enthusiast Joined Apr 12, '04 From Nj Team 6gc Currently Offline Reputation: 0 (0%) |
koni had front and rear shocks and struts for 94-97 but they skipped out on the 98-99's. question is will they fit my 98 GT.. or would custom fabrication be needed. if fabracation is needed, then how would i go about doing it. thanks in advance to all who reply~ holla
-------------------- Team 6gc 2oo5
May 8, 2004 - 4:49 PM |
Enthusiast Joined Aug 30, '02 From Franklin,Tn Currently Offline Reputation: 0 (0%) |
All they are are just inserts into the strut housing. All that has to be done is remove the stock struts and put the koni's in there place and then reinstall the whole shock/strut housing.
Bryan |
May 25, 2004 - 5:36 AM |
Enthusiast Joined May 24, '04 From state of northern virginia Currently Offline Reputation: 0 (0%) |
well...mostly true. remove the front stock inserts, install the new inserts. remove the rear strut assembly. cut the top of the rear strut assembly, drill the center of the bottom of the assembly. blah blah blah (only blah blah, because can't remember exact steps). install new insert, bolt it in, install the strut assembly. and drive away!
Lo-Fi Version | Time is now: January 11th, 2025 - 3:54 PM |
