Sub Installation Help, No idea wtf im doing wrong! |
Feb 13, 2003 - 7:37 PM |
Enthusiast Joined Sep 13, '02 From Maryland Currently Offline Reputation: 0 (0%) |
Feb 13, 2003 - 7:41 PM |
Enthusiast Joined Feb 3, '03 From Pensacola Florida Currently Offline Reputation: 0 (0%) |
one thing you can do is hook up a speaker that you already know is working to your amp outputs just to see if your getting anything to the speakers in the first place
Feb 13, 2003 - 7:52 PM |
okay anything else i can do? Thanks man
Feb 13, 2003 - 8:09 PM |
Turn your Subs on - on your deck. My Pioneer deck had a function you need to enable to activate Subs.
Feb 13, 2003 - 10:24 PM |
I tryed messing with the deck but i cant find anybutton on there that turns them on.. I have the JVC KD-SH909R model if that helps. When i looked the cd player up on line it says it includes a subwoofer line out??? Not sure what that means.. Thanks again for the help. People here at 6gc.net are the best!
http://www.jvcmobile.co.uk/html/kd-sh707r.html Tyler |
Feb 13, 2003 - 11:38 PM |
Enthusiast Joined Jan 20, '03 From Denver, co Currently Offline Reputation: 0 (0%) |
the stereo has rca outputs on the back, thats usually what a sub line out means. Did you hook your rca lines to them?
Feb 13, 2003 - 11:54 PM |
Enthusiast Joined Oct 31, '02 From grants pass oregon Currently Offline Reputation: 8 (100%) |
usally when a deck has a sub line out there is also a seperate control for the subs. if there is it could be turned all the way down witch would mute the subs
Feb 14, 2003 - 12:28 AM |
Enthusiast Joined Nov 12, '02 From bayarea Currently Offline Reputation: 0 (0%) |
You ****in noob! oh wait we're not on celica.net hahaha So if the amp is working then your power, ground and amp led is hooked up correctly. lemme see. again, check on your deck to make sure the sub volume is up it should be in the same section as bass, treb, fade, balance, etc. Um, make sure your rca plug is hooked up to the sub preamp on the back of your deck. Take the subs out of the box and directly test each of them to the amp by hooking up wires. how many channels is your amp cuz if its more than one you should test subs on both channels as well as bridged. You could also try another rca cable or try plugging it into the front or rear preamp input on the back. Make sure youre not plugged into the aux input. that's about all i can think of. good luck.
Feb 14, 2003 - 1:20 PM |
Hey all thanks for the replies.. As soon as i get home i am going to try your suggestions and see if it works. Ill let you know how it goes!
Tyler |
Feb 15, 2003 - 11:17 AM |
Alright I think I figured out the problem.. It has something to do with the ground wire. When i touch a screw driver against metal it grounds it and the subs work. I tryed grounding the wire then to a screw in the bottom right hand corner right above the right rear wheel but for some reason that dosnt work. If i hold screw driver against the screw and then to the side where it is metal than it works. hmmm?? If you guys have any pictures of your wriring and where u grounded your wires it would be much appreciated. Sorry if this thread keeps coming up.
Tyler |
Feb 15, 2003 - 9:11 PM |
Enthusiast Joined Aug 30, '02 From Rolla, Misery (Missouri) Currently Offline Reputation: 0 (0%) |
did you scratch away all the paint from the spot you're grounding? that may be a problem. i grounded min in the strut tower screw. oh course my amp sits only a foot away and it's a straight shot. i'll take a pic and post it when i get home tomorrow.
Nathan |
Feb 16, 2003 - 12:27 AM |
Ground it to one of the bolts on your seat.
Feb 16, 2003 - 4:01 AM |
Enthusiast Joined Nov 11, '02 Currently Offline Reputation: 0 (0%) |
if you look between your back seats underneath the bit of seat fabric at the back, you will see three bolts going into the body. these three bolts are connected to a thing that holds the seats in place. undo one of those bolts and ground your wire right there. i am telling you, that is the best place on the car to ground it.
Feb 17, 2003 - 1:28 AM |
Enthusiast Joined Sep 4, '02 From Meridian, MS Currently Offline Reputation: 0 (0%) |
LOL! That was funny
Thats where mine is grounded at, Ive had no problems. |
Lo-Fi Version | Time is now: November 24th, 2024 - 10:33 AM |
