A/C Works! |
A/C Works! |
May 9, 2004 - 12:20 AM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
So today, while I was at my body shop getting an estimate, my A/C got brought up. The owner then told me that they have a recharger. After recharging the system, we tested the A/C and it worked as it did before the swap. WOO HOO! Now I can drive my car comfortably through Cali's sweltering heat. Despite the fact that they lag, EL Prototypes does nice, clean work!
May 9, 2004 - 12:54 AM |
thats great news.
im kind of worried about mine. i have a black car with black leather. i be **** out of luck if mine didnt work. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 9, 2004 - 7:23 PM |
Enthusiast Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) |
wish my a/c worked, the compressor doesn't even kick on when I press the a/c button. But I don't really want to spend $150 to buy a new one.
May 11, 2004 - 10:03 AM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
There is a pressure safety switch that keeps the compressor from coming on and burning up if the freon is too low, you may just need to add a little freon. |
May 11, 2004 - 11:37 PM |
Thanks for the advice my car is going into the shop next week maybe I'll have them check it out. |
May 12, 2004 - 9:25 AM |
Enthusiast Joined Jan 16, '04 From Texas Currently Offline Reputation: 0 (0%) |
Is it pretty common for the ac not to work after the swap?
and will recharging it work everytime? or what is it that actually keeps the a/c from working. |
May 13, 2004 - 5:46 AM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
Hey kuya, did you use the comperssor for the 5s or 3s?
May 13, 2004 - 9:07 AM |
if the A/C on a car is anything like the one for your frig.. it will loose compression once it's disconnected... nothing wrong with it .. just has a no compression so you need to add some coolent what ever it uses... and this well cause the unit.. to gain compression again.. well i don't know if that makes sence to anyone cause i'm supersleepy and the world just look like dots to me right now... and yea what i just said is the case it the A/C unit works just like the ones on your frig at home -------------------- |
May 13, 2004 - 10:34 AM |
From the 5S bro. |
Lo-Fi Version | Time is now: December 2nd, 2024 - 8:02 PM |
