> Check engine light Tool
post May 9, 2004 - 8:22 PM
djspike
Joined Apr 23, '04
From WA
Any body know where you can buy the check engine light tool?
and how much? (roughly)
post May 9, 2004 - 8:54 PM
macavely
Joined Nov 4, '02
most parts store carry them.. i'm not sure how much they cost ... some were around 100 bucks for any obdII
This post has been edited by macavely: May 10, 2004 - 7:30 AM
post May 9, 2004 - 9:20 PM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (djspike @ May 9, 2004 - 7:22 PM)
cant you just use a paper clip?
i am awesome
post May 9, 2004 - 10:50 PM
djspike
Joined Apr 23, '04
From WA
i thought you cant do that with a 96
post May 9, 2004 - 11:21 PM
orvillescelica
yeah, ive been wondering this too. The chilton manual says to use the tool for 96+. Do you think any places rent/lends them?
post May 9, 2004 - 11:25 PM
macavely
Joined Nov 4, '02
yea i think autozone does.. well one of their people will come out and do it for you..
post May 10, 2004 - 12:07 AM
djspike
Joined Apr 23, '04
From WA
we dont have a autozone here
we have shucks and Napa
post May 10, 2004 - 12:20 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
well I have a 97 and umm I use my diagnostic tool, its a stripped wire biggrin.gif You need to use one of the smaller paperclips, big ones dont fit to well.
as far as I know there would be no reason for them to change the diagnostic port...
post May 10, 2004 - 1:00 AM
KnightRider
i thought that obd1 was in 94-95 in which you need a jumper (aka paperclip) to get the code and a 96-99 was obd2 where you can use the little thing you plug in and it tells you.
post May 10, 2004 - 1:09 AM
djspike
Joined Apr 23, '04
From WA
so chrobis you use a small paper clip(trick) and it works for your 97?
post May 10, 2004 - 1:30 AM
ssnake86
Joined Mar 18, '04
From San Diego
you insert paper clip where? and what does it do? gives you a code?
post May 10, 2004 - 1:46 AM
macavely
Joined Nov 4, '02
QUOTE (ssnake86 @ May 10, 2004 - 1:30 AM)
look at the how to section.. it shows you on there what everyone is talking about
post May 10, 2004 - 11:46 AM
Chrobis
Joined Apr 15, '03
QUOTE (ssnake86 @ May 9, 2004 - 10:30 PM)
Yes you insert the paper clip into 2 slots and then a magical reaction ocurs and your engine, with a strong deap voice, tells you any problems it is having rolleyes.gif
Check out the how to section like mac said, and OBD and OBDII are smog systems, not diagnostic systems. Why would this have anything to do with the Diagnostic port.
post May 10, 2004 - 12:19 PM
Dont buy anything, use a paperclip.
And my car has a sexxy female voice...idk man i'd have issues riding around knowing my car sounded like Darth Vader.
This post has been edited by Supersprynt: May 10, 2004 - 12:19 PM
post May 10, 2004 - 12:22 PM
aaronc222
Joined Sep 22, '02
From Detroit
QUOTE (Chrobis @ May 10, 2004 - 12:46 PM)
On Board Diagnostics(OBD) is not a smog system. That's the EGR and cat. converter.
post May 10, 2004 - 6:22 PM
djspike
Joined Apr 23, '04
From WA
then why is every body saying you cant do that trick on 96 and above?
post May 11, 2004 - 2:20 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
buy a haynes manual. they will tell you what pins to jump on the diagnostics plug
if you just want to turn the CEL off, disconnect the battery for 5 minutes
post May 11, 2004 - 1:55 PM
Chrobis
Joined Apr 15, '03
hey instead of spending the $20 on the haynes, go to the How to section right here on this webpage!
post May 12, 2004 - 2:38 AM
ssnake86
Joined Mar 18, '04
From San Diego
sorry for not knowing this. but where do i stick the paper clip in?
post May 12, 2004 - 2:46 AM
macavely
Joined Nov 4, '02
QUOTE (ssnake86 @ May 12, 2004 - 2:38 AM)
check here
click this now
Lo-Fi Version Time is now: November 28th, 2024 - 11:44 PM
