Intake for 3sgte, stock vs. aftermarket |
May 10, 2004 - 10:42 AM |
I have read that aftermarket intakes for turbos do not result in significant performance gains like in n/a cars. I have also read that they can significantly increase noise which I do not want. Please let me know what differences I can expect with an aftermarket intake on the 3sgte. Thanks for the replies.
- Jay. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
May 10, 2004 - 11:42 AM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
Well the truth is you do want the turbo to have as much free flowing air as possible. By adding an intake it removes the "restrictive" stock air box.
Also, you would only need a "Ram" type, and not a cold air intake type, because even if cold air gos into the turbo it will come out hot, thats what your intercooler is for. |
May 10, 2004 - 11:49 AM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
don't spend your money on it.
It's not worth it. |
May 10, 2004 - 12:14 PM |
Did you do your swap or are you going to do ur swap. Your info suggests that u've already done the swap. So my question is, how are u using a stock 3s airbox? It will not fit properly in your engine bay even if you did relocate the battery. Your going to need a custom set up anyways so you basically have no choice but to get an intake. Its not something thats going to get your any real performance its simply a base in which you will build up from. Turbos suck in air at a much greater force than any n/a so the less the turbo has to work to get the air it needs the better.
This post has been edited by Supersprynt: May 10, 2004 - 12:17 PM -------------------- |
May 10, 2004 - 12:54 PM |
My listed info is what I am doing. All parts are purchased except wheels which are being ordered this week. Car will be going to the mechanic at the end of June. Thanks for the info. I had no idea the stock air box would not fit.
Any recommendations on intakes? Super, I see your profile says "custom" what did you do? - jay. This post has been edited by jgreening: Jun 26, 2004 - 6:20 AM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
May 10, 2004 - 1:19 PM |
Enthusiast Joined Mar 21, '04 From united kingdom Currently Offline Reputation: 0 (0%) |
custom is the way 2 go my friend:
70-80mm reducer hose (used as expander!) connected 2 turbo custom 80mm metal tubing with 2x 16mm tubes welded onto it some 80mm hose 80mm inlet filter (dry paper type) 140mm accross 250mm long or if u want of the shelf get the apexi btw you said you dont want your car 2 be louder, but your stock recirc dump valve will be loud like an atmospheric This post has been edited by uzthedentist: May 10, 2004 - 1:25 PM -------------------- GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10 |
May 10, 2004 - 4:23 PM |
UZ is lucky, he doesnt have an AFM. With the ST185 theres a big ol annoying AFM, it greatly reduces ur options. I took my 5sfe intake tubing, and cut it to fit. And then i put on a K&N filter.
Also, the St185 engine doesnt have a stock recirc. valve. The intake will make you hear the turbo spool tho, but thats cool. This post has been edited by Supersprynt: May 10, 2004 - 4:26 PM -------------------- |
May 10, 2004 - 4:35 PM |
has he got a 185 engine? u can still fit a str8 intake u just need a toip hat adaptor
May 10, 2004 - 4:42 PM |
He can fit a straight intake however he'll still require the AFM. And the battery is right in front of the turbo. The cruise control is in the way also, it needs to be removed. For a straight intake he needs to relocate the battery. And after he did all that he would have to extend the plug for the AFM, it will be to short. -------------------- |
May 10, 2004 - 6:08 PM |
get a 205, much simpler lol -------------------- GT4 ST205 79 modifications and rising!!
May 11, 2004 - 1:54 AM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
That's what I did... but getting the Apex'i Intake wasn't easy. I had to wait close to a year to get it from a guy in Germany. I think his name is Pooya or Puya... he's on the MR2 boards. This post has been edited by kuya1284: May 11, 2004 - 1:54 AM |
May 11, 2004 - 11:56 AM |
The intake might be much simpler, but that swap isnt.
May 11, 2004 - 1:44 PM |
You could also get the AFM deletion Kit from bulletproofautomotive.com and you wouldnt have to use the AFM at all.
Of course you need to send them the ECU, and wait about 10 weeks... |
May 11, 2004 - 7:54 PM |
if u do that mine as well get a stand alone with MAP and then u'll get a lot more power capabilities.
Lo-Fi Version | Time is now: January 10th, 2025 - 9:13 AM |
