help, does anyone know what... |
May 12, 2004 - 10:26 PM |
Enthusiast Joined Dec 20, '02 From OKC Currently Offline Reputation: 0 (0%) |
does anyone know that the machine that measures the rms watts of an amp is called im looking to buy one but i need to know the name of it. thanks
DREW |
May 15, 2004 - 7:33 PM |
Enthusiast Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
Look for a "true RMS meter"
Measuring the output of an amp isn't as simple as hooking up a meter. Music signals change so much the power jumps. To get accurate readings you need to use a signal generator and check the amp at different freq. Also you need to put a 4ohm load on the amp to get accurate readings. It really isn't that easy and you could smoke the amp. |
Lo-Fi Version | Time is now: November 29th, 2024 - 3:38 AM |
