2 Pages V  < 1 2
> gas, different octanes....
post May 14, 2004 - 5:27 AM
KAMiX
Joined Mar 4, '03
I don't know about the states but I am fairly sure that Japan uses the same ratings as Europe and Australia because they share some of the fuel "names".
I run on BP Ultimate 98 and my car runs absolutely sweet. Much smoother through the revs and a little bit quicker at the top end.
post May 14, 2004 - 12:00 PM
97GTinKC
From KC
It does state in the owners manual (for a 5sfe) "use 91 octane for best performance" or something like that, you can use 87 with no problems, but the computer will retard the timing more to prevent detonaton, which will hurt performance. The stock compression on the 7a is quite a bit lower than the 5s, so it wouldn't make as much difference (if any)
post May 14, 2004 - 1:19 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (Chrobis @ May 13, 2004 - 10:25 AM)
Actually kuya and everyone else the 5s is actually recomended to run 91 octain rolleyes.gif The owners manual says it. But, it said it is ok to run 87, better to run 91 or something like that. Should you? probably not wink.gif
Sprynt you think your unlucky with your gas, CA only offers up to 91 octain!
Yeah, the manual says that it's recommended to run 91 octane (for 5S motors), but not necessary, since the motor was designed to run on 87 octane (like I said in my previous post). wink.gif
post May 14, 2004 - 1:24 PM
kuya1284
Joined Nov 15, '02
QUOTE (celicarocker @ May 13, 2004 - 6:03 PM)
i have a stock (engine wise) 95 ST.... 142k....
will i gain anything from putting a higher octane gas in my car? people have conflicting views on this....
post May 14, 2004 - 1:27 PM
kuya1284
Joined Nov 15, '02
QUOTE (97GTinKC @ May 14, 2004 - 10:00 AM)
Yeah... and unless your car is actually knocking or pinging, there is no point in using 91+... Unless you feel like spending the extra money...
post May 14, 2004 - 1:42 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
well I do agree that you should use 87 for the 5s and 7a motors... but I dont have to worry about that anymore wink.gif
post May 16, 2004 - 7:35 PM
KAMiX
Joined Mar 4, '03
Yeah Kuya I also think a bit part of the difference I notice in my car is that the BP Ultimate I use is not only higher octane but the fuel is much cleaner and has been processed more than regular.
2 Pages V  < 1 2
Lo-Fi Version Time is now: January 7th, 2025 - 7:49 PM
