Removing the heater controls |
Mar 9, 2003 - 1:23 PM |
Enthusiast Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
[B]Its to EASY,, i remove it all the time.. the blue cable is the easiest one, it goes to the switch in the back, pop off the little black top then pop off the blue cable.
The black one connects right to the back of the heater control unit. It connect into a little whole on the white part that sticks out, its two easy..Email me if u need help.. |
Mar 18, 2003 - 10:12 PM |
Enthusiast Joined Jan 13, '03 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
I had the same problem with the rest of you since I have two amps. One under the heater controls and I have one under the driver seat. I spent to many hours trying to get the wireharness out of the amp under the heater control so I just ended up cutting it and attaching it to my new Kenwood deck. Either way you have to disconnect one amp so cutting it will be easier. Assuming you know what color is what when connecting the cables.
Thats my 2 cents for you all. |
Lo-Fi Version | Time is now: November 25th, 2024 - 2:33 PM |
