Sunroof Question, Need some advice |
May 13, 2004 - 3:39 PM |
Enthusiast Joined Dec 7, '03 From CANADA Currently Offline Reputation: 0 (0%) |
Hey guys...
I hope i can explain this right but here we go.....one of the tabs that hold down the sunroof arms when the sunroof is open has come unattached itself from my roof. So one side gets blown up when I drive on the highway and it causes all kinds of annoying turbulance noise. It seems that it is held to the roof through glue so Im just wondering what kind of glue is good to bond plastic to metal? |
May 13, 2004 - 7:47 PM |
Enthusiast Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
two part epoxy....
you buy it and it comes in like this thing that looks like a big seringe with 2 tubes, squeeze some out, mix it together, then you have like 30 secs before it dries.... stuff holds very well... -------------------- |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Ive got the same problem. it looks so goofy sticking up
May 13, 2004 - 10:34 PM |
Enthusiast Joined Sep 22, '02 From Detroit Currently Offline Reputation: 0 (0%) |
Mine's been broken for a few years now. It started bugging me so I just put the sunroof visor back on. There is a screw in the one that broke on me, but the plastic around the screw is what broke. It's been glued several times with various glues(including industrial stuff when I was working at a print shop), but it always seems to break again.
May 14, 2004 - 7:27 AM |
Enthusiast Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
same exact thing happened to me. i took the peice that held the screw, and a self tapping screw and screwed it in. it looks fine and holds great. cant even notice cauz it was a black screw. |
Jan 20, 2005 - 10:09 AM |
Enthusiast Joined Nov 30, '04 From New York Currently Offline Reputation: 0 (0%) |
I just fixed mine. i dont think that self tapping screws are the way to go, i just went to home deopt and picked up some Stainless 8-32 screws that were 3/4 in thick (you might want to go metric on that) and two stainless fender washers. i had to grind the screws down just a little bit but if you place the fender washer on top of the pastic tab and then screw the screw in to the regular hole with that broken "washer" then it works great.
This post has been edited by SkaBass1: Jan 20, 2005 - 10:09 AM |
Lo-Fi Version | Time is now: November 24th, 2024 - 11:26 PM |
