Oil light question |
May 15, 2004 - 7:01 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Does anyone's oil light come on for a second when you take a sharp corner? I checked my oil level and it seems to be ok, what could be causing this anyone know? I have the 7afe btw with 114k on it.
May 16, 2004 - 2:36 AM |
Enthusiast Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
same thing happen to me i checked it right away
and oil was fine then i left it over night took the stick out cleaned it put it back and took it out again and looked what it said and it was low so it was low oil This post has been edited by djspike: May 16, 2004 - 2:37 AM |
May 16, 2004 - 5:13 AM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
it happens me too sometimes....maybe the oil pump is dirty so it has difficult to pump oil when under hard lateral accells...
May 16, 2004 - 10:11 PM |
Well my oil was low, so I put some in it. I also found the problem, I have a leak somewhere around my timing belt. I'm gonna take the cover off tommorow and see if its the cam seal, or where it is coming from. I'm also gonna change the timing belt while I have it apart, fixing the leak.
Lo-Fi Version | Time is now: December 3rd, 2024 - 3:04 PM |
