> Intercooler and Piping?, what will fit with the gt4 bumper
post May 17, 2004 - 7:24 AM
i need some help buying correct size intercooler and piping that will fit behind the gt4 bumper. this will be used for a 3sgte engine swap. please post size, brand and place where you bought yours.
post May 17, 2004 - 11:08 AM
uzthedentist
Joined Mar 21, '04
From united kingdom
mine is 600mmx300mmx80mm custom made and the piping is 2.5 inch. make sure u dont run over 650mm across otherwise ull have difficulty in making it fit
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post May 17, 2004 - 4:35 PM
Magic
Joined Mar 30, '03
From Cyprus
Hmmmm, why do you want to change the stock intercooler?Are you going to change the stock turbo?Or raise the boost???
I dont think its necessary for standart Turbo to get Aftermarket Intercooler. rolleyes.gif
post May 17, 2004 - 5:05 PM
Mynzeyes
From Franklin/Nashville, TN
QUOTE (Magic @ May 17, 2004 - 3:35 PM)
If it is an ST185 3sgte, then the stock intercooler will do no good, seeing as it's a top-mount. With the ST205 hood, very minimal air will get to the TMIC, which will cause a great amount of heatsoak, thus requiring the moving of the intercooler to the front, seeing as how an aftermarket FMIC would be much cheaper than the ST205 W/A intercooler setup.
-John-
AIM==Mynzeyes
post May 17, 2004 - 5:53 PM
QUOTE (Magic @ May 17, 2004 - 2:35 PM)
it has a 5sfe engine in it now and im planning to swap an ST185 3sgte into it someting this month. so, im going to need a FMIC because the stock one wont work well.
post May 17, 2004 - 11:51 PM
Magic
Joined Mar 30, '03
From Cyprus
post May 18, 2004 - 12:35 AM
Jabberwock
Joined Sep 22, '03
There is a custom made 3rd Gen 3SGTE W/A intercooler that can handle 450+ WHP on ebay if you are intersted, which may be better than a FMIC you are looking for since there is less piping.
Lo-Fi Version Time is now: December 4th, 2024 - 9:04 PM
