> window seals, ripped
post May 18, 2004 - 7:48 AM
blkGT
Joined Jun 10, '03
From FL
do you think that toyota sells these, they are at the bottom of the window. once its been rolled down there is one on the inside and outside on top of the door panel, and both of them are ripped and they flap around. sorry i dont know how else to explain it.
post May 18, 2004 - 8:21 AM
celicarocker
Joined Sep 25, '03
From cranston RI
mine too.... but only on the drivers side... i just deal with it...
post May 18, 2004 - 8:36 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
QUOTE (blkGT @ May 18, 2004 - 12:48 PM)
If your talking about the rubber that is attached to the top of the door panel, yes Toyota sells them.They are around $30 for each door panel, and they come off by lifting the tabs on the backside of the door panel.
post May 18, 2004 - 9:33 AM
celicarocker
Joined Sep 25, '03
From cranston RI
i believe he means the rubber thats on the actuall door, like when you roll down the window, that rubber down there....
post May 18, 2004 - 10:10 PM
blkGT
Joined Jun 10, '03
From FL
QUOTE (celicarocker @ May 18, 2004 - 7:33 AM)
yea, it seals the bottom of the glass to the door when the window is up. glad to know im not the only one with the problem celicarocker. im thinkin of superglue.
Lo-Fi Version Time is now: February 18th, 2025 - 2:15 AM
