> Re-building...7afe, what is available?
post May 19, 2004 - 3:06 PM
NeWTyPe
Joined Apr 28, '04
From CALIFORNIA
i was thinking and getting ready to rebuild my 7afe engine....i dont know of any sites or such for RODS or PISTONS....i was asking for some help and options...
to re-build.....
PISTONS??
CAMS???
RODS???
anything or help would be great.....thanks
post May 19, 2004 - 3:10 PM
JDM7afe
Joined Mar 3, '04
From Las Vegas
arias makes pistons, i dont know about the other stuff. my mechanic said it would cost about 2k to rebuild the blown usdm 7a i had.
post May 19, 2004 - 4:02 PM
BigEdge169
Joined Nov 18, '02
From Texas
Custom is pretty much your only option. The 4agze pistons will fit but that won't do you much good unless you plan to turbo because I believe they'll lower the compression ratio.
post May 19, 2004 - 6:46 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
i thought the made dome pistons for n/a 4a's. anyway, i always go to raceeng.com (or net, i'm not sure). they have a good selection of the top names in engine components. you won't find anything specifically for the 7a but they can make you a set of custom rods to fit some 4a pistons.
post May 19, 2004 - 11:24 PM
FallenHero
Joined Dec 26, '02
From Alabama
just use the 4a pistons and a 4a Blitz (or hks) .5mm head gasket. that should help out with the compression change. I'm fairly sure the 4a gasket will work. after all, the head itself does. wink.gif
post May 20, 2004 - 2:22 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
4afe and 7afe heads are the same... use a 4a-fe head gasket to gain compression, as well as using 4a-fe pistons on a 7a-fe....
if you want a spare head to have built or P&P and not have downtime, i have a 4a-fe head for sale ($50 plus shipping, as is... should be machined and possibly new valves)
post May 20, 2004 - 2:27 AM
macavely
Joined Nov 4, '02
QUOTE (JDM7afe @ May 19, 2004 - 3:10 PM)
WTF a new one is 1600 bucks
post May 21, 2004 - 12:00 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE (macavely @ May 20, 2004 - 12:27 AM)
sad but true. or so I'm told... I really want a spare 7a to work on these days. I took a ride in my friends GST elipse... powerful machine...
Anybody in the fl, Ga, Tn area got a spare 7a?
post May 21, 2004 - 11:41 PM
DustyBurns30
Joined Jul 31, '03
i have everything but the block and two pistons/rods.
post May 22, 2004 - 11:37 PM
FallenHero
Joined Dec 26, '02
From Alabama
Lo-Fi Version Time is now: April 24th, 2025 - 7:22 AM
