> engine motor mounts, need parts#,who knows
post May 26, 2004 - 12:16 PM
alex3sgte
Joined Sep 5, '02
From Puerto Rico
Hi everyone,Im in the procces of the 3sgte engine swap into my 7afe 1994 celica and I need the original toyota part# for the front,rear,passenger and driver motor mounts from 1994 toyota celica GT-S with 5sfe engine,because thath the engine mounts that Im goona use.Please part#s for all the 4 mounts. wink.gif
post May 31, 2004 - 3:50 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
are these the best mounts for the swap, i'm doing it too
post May 31, 2004 - 6:42 PM
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74330 RH
post May 31, 2004 - 7:20 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I have a question, nt to steal your thread.. But The motor i bought has the mounts on it.. Its the 3s-ge .. not the beams.. but thopse mounts should work for my st? right? Thanks
post Jun 1, 2004 - 2:53 AM
titaniumkid
Joined Mar 2, '04
From Little Rock, AR
QUOTE (Digndoug @ Jun 1, 2004 - 12:20 AM)
im pretty sure as long as you have 94-99 gt motor mounts, that block will mount up
post Jun 2, 2004 - 7:26 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
QUOTE (presure2 @ May 31, 2004 - 11:42 PM)
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74330 RH
the toyota deal said one of these is wrong
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74430 RH
it is going to cost over 300 for all of these from the dealer
where else should i try to get these
i tried local auto parts stores but those numbers didn't transfer into anything
post Jun 2, 2004 - 7:37 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
Two words....Junkyard Celica =)
post Jun 3, 2004 - 8:20 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
you can get urathene mounts, go to your local performance shop.
they can used the old mount and pop the urathene insert in.
post Jun 4, 2004 - 7:48 AM
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74430 RH
do you know which one?
12362-74430 RH this is the wrong one...the right # is 12362-74330
This post has been edited by presure2: Jun 4, 2004 - 7:49 AM
post Jun 4, 2004 - 11:00 AM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
it doesn't matter if you have a ST or a GT.
The FRONT and BACK mounts are identicle. You can use your existing ST mounts. The only thing you have to buy are all 4 Motor Mount Brackets and the Driver and Passenger side mounts for a GT. That's less money you have to spend.
post Jun 6, 2004 - 10:18 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
QUOTE (presure2 @ Jun 4, 2004 - 12:48 PM)
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74430 RH
they told me 12362-74330 RH is wrong that its 12362-74430 and it $197
ok so all i need is driver and passenger side mounts
Lo-Fi Version Time is now: November 25th, 2024 - 3:05 AM
