> squeeky brakes..., its not the pads
post May 29, 2004 - 6:18 PM
Element23
Joined Nov 17, '02
From Mission Viejo, CA
So lately my car has been pretty gay with its brakes. When im stopping from an average speed (anything above 20 or so mph), i hear my rear drums making a type of Grinding noise. i checked my shoes and they were fine. I had replaced my drums a few months ago thinking this would solve stopping issue, but i always hear this noise...
Also, my front brakes tend to be squeeking a bit, checked those also, but the pads still have a good amount of life on them, and solutions?
ONE more issue. When stopping from a normal speed, and at average pressure on the pedal, my my steering wheel tends to shake a bit between 20-40 mph. I checked my wheels and they are on pretty well. I was thinkin it could be the rotors... help would be appreciated.
post May 29, 2004 - 7:43 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Element23 @ May 29, 2004 - 4:18 PM)
Well shaky steering wheel can be alot of things, does it happen when stopping? If so you probably have warped rotors. Ive also heard that celicas have a tendancy for squeeky brakes but thats just what Ive heard from owners around here.
If your stearing wheel shakes while accelerating then it could be a flaw in the tires like a bulge or uneven tread wear. Ya may need your wheels balanced also. But Ive found that new tires on a car are like the best feeling ever, theres alot of little things that come with aging tires and usually lead you to think something else is wrong with the car when infact its only the tires.
post May 29, 2004 - 7:53 PM
Element23
Joined Nov 17, '02
it only shakes when braking. but thanx for the info. im pretty sure the wheels and tires are balanced too, tires are only about 5 or so thousand miles old
so i guess i need new rotors... frown.gif . Ive looked around at the Stock Brembo rotors, so thats an option. but mostly, im looking at price. Any suggestions?
post May 29, 2004 - 8:01 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
DEF
I will return one day.
post May 29, 2004 - 8:19 PM
celicarocker
Joined Sep 25, '03
From cranston RI
yeah, do what jeff said... my new rotors were like that when i put them on, so i got them cut, and they were fine...
post May 29, 2004 - 8:38 PM
Element23
Joined Nov 17, '02
how much is it to get the rotors cut?
post May 29, 2004 - 8:47 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Element23 @ May 29, 2004 - 6:38 PM)
Probably like half the cost of new ones, and they wont last as long as new ones, and depending on how bad they are warped they may not even be fixable. Id just cough up the extra cash for new rotors since they arent all that expensive to begin with.
post May 29, 2004 - 11:57 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
if you find the right shop and you pull them out yourself. you could prolly get them cut for like 10 to 20 bucks
sorry I missed ur IM........
Later
DEF
post May 30, 2004 - 5:31 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
some brake pads squeek no matter what. I like ceramic pads...they dont make any noise and dont produce any black dust.
post May 31, 2004 - 2:34 PM
Exile04
Joined Aug 20, '03
From Seattle, Washington
A reason they might make noise is because of salt...has it been rain lately if so that might be why...the Salt in the rain gets to the brake then they start to make nosie mine do it for aobut 2-3 days and stops.
post May 31, 2004 - 8:33 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (Element23 @ May 29, 2004 - 9:38 PM)
at my shop, if you pull off the rotors yourself we charge 16 + tax to machine (cut) them, and even if you get new rotors its best to have them machined before you put them on. as far as noise, you brake pads have probably crystalized themselves and that is what is causing the noise. you could either replace the pads or live with the noise.
post May 31, 2004 - 9:10 PM
latinomasfino
Joined Feb 17, '04
yea my steering wheel shakes too but its sometimes when i stop at a light. when i put my hands on the wheel it stopps but when i let go its shakes any suggestions to wut it might be?
post Jun 1, 2004 - 10:59 AM
blkGT
Joined Jun 10, '03
From FL
warped rotors?
post Jun 2, 2004 - 2:20 AM
Element23
Joined Nov 17, '02
checked the brakes on monday, all is well, so its definitely the rotors. the pads still have a good 1.5-2 cm on them, so Beefstew is most likely right, since its been doing it since i got the pads, they are semi-metallic so hey kinda suck, im over it though.
post Jun 2, 2004 - 2:21 AM
Element23
Joined Nov 17, '02
that is one long ass run-on sentence. Feel free to bucher that as much as you want.
Lo-Fi Version Time is now: November 27th, 2024 - 2:11 PM
