Part #'s for lowering suspension |
May 30, 2004 - 11:29 PM |
Enthusiast Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
Having my car repainted this week and installing factory skirts.
I want to also lower the ride with eibach sportline springs and install new shocks/struts without having to cut anything. Seems KYB is the oem choice. Also read in a few posts, guys suggesting changing a few other items? Is it better to have the eibach alignment kit installed? Should the bushings or swaybar links be changed also? car: '94 Celica ST Coupe Parts and #'s so far: Eibach Sportline Springs: 4.0782 Kyb GR-2: front right: 365092 front left: 365092 rear left sturt: 334126 rear right strut: 334125 front right mount: sm5164 front left mount: sm5164 rear right mount: sm5087 rear left mount: sm5087 front right boot: sb103 front left boot: sb103 rear right boot: sb103 rear left boot: sb103 This post has been edited by exxtractor: May 31, 2004 - 12:14 AM |
May 31, 2004 - 12:38 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
No you don't need the alignment kit, our cars come adjustable from the factory. Just go get your car aligned after you changer your struts and lower your car.
Jun 1, 2004 - 5:44 PM |
Do we need the right and left front mount? I know tirerack.com doesn't sell it, but I didn't read of anyone ordering this?
Jun 1, 2004 - 6:30 PM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
I replaced my OEM's with KYB's not too long ago. Well no longer then a month ago. I was going to change the front mounts but after inspecting my fronts they were ok. I don't think it's that necessary to replace them. If you REALLY want ALL new parts...then order them, but it's up to you.
If you need the PN's I got them available... KYB-SM5164 $40 each at coximport.com Edit: woops didn't see you already had the PN's for the fronts already listed. This post has been edited by CelicaQT: Jun 1, 2004 - 6:33 PM |
Jun 1, 2004 - 6:38 PM |
You don't need to replace the bushings unless you're maybe getting swaybars. I DO suggest changing your RR Swaybar link. Since you have a 94 it might and could be a pain to remove your RR links. I changed mine and replaced with the TRW's. It would be wise to do so, that way you won't risk stripping that Hex head when removing your RR strut. Check www.partsamerica.com, www.rockauto.com, local Murrays, etc. for them. If you need PN's for those also I have them available along with pics of my KYB/TEIN install. |
Lo-Fi Version | Time is now: November 24th, 2024 - 12:50 AM |
