![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) ![]() |
nice bolt on my son muahahahaha
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
What exactly you guys mean, lifting the door?? .. Like , you open it, an it pops up... does it go up farther.. I was thinking about doing this, but it just seemed like it would be hard or a pin to get in an out of.. Thanks
![]() Enthusiast ![]() ![]() Joined Aug 30, '02 From NYC Currently Offline Reputation: 0 (0%) ![]() |
with proper vertical doors you can get in and out without swinging the door upward. it should first swing out (with enough room for you to get in and out) and than if you want it swings up. if yor inside the car the easiest way for you to "lift" the door to push it up from the bottom of the door. |
![]() Enthusiast ![]() ![]() Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) ![]() |
Great job man. I've been wanting lambo doors for a while now, but soundslut was the only celi id ever seen w/ them. Thanx for givin me some hope. I was gonna wait till next yr. to do mine, but i may shoot for the end of this summer now. Please get up some more pics when ur done and maybe a how-to.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) ![]() |
Just an update, latches are back from the welders who filled in some half-moon crevices on the mounting plates. Im determined to keep the latches bolt on both sides(body and door). I could very easily be done with the project, if I weld the latches to the door side. But I rather do the extra work and make them removable. The latches bolt right up to the body side. I would say now that it is very easily possible to Lambo door the 6th gen celica, and actually any car out there.
Next stop is the machinist at work. I got to slot the mounting holes so I can have some adjustment. The plate is too thick to do it with a dremel. The problem is its hard to get the latches in a mill, since you can not take them apart. Main hinge is welded closed. The slot will allow the door to move in/out closer to the fender. the latches have 2 adjustments built in. One is how far the door will open before it goes up, and the other is moving the door up or down so it catches on the striker when you close it. So hopefully next weekend I can put both latches on so I can mark the holes, and off the machinist. I was able to get away with not extending the wiring harness. I cut the middle off the rubber wiring boot and added plastic loom. |
![]() Enthusiast ![]() ![]() Joined Sep 18, '03 From Dirty Jersey Currently Offline Reputation: 0 (0%) ![]() |
My friend and i are trying to make some and we have connections at a machinest shop and welding shop. all i need to know is how thick is the metal on the hinge and i was assuming it is steel. anything else you could help on would be great too.
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:18 AM |
