Enthusiast ![]() Joined Sep 28, '03 From UK Currently Offline Reputation: 0 (0%) ![]() |
Have this appear from time to time on my jdm SSII does this indicate low pressure oil??? if yes got any suggestions why this is
cheers guys |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
I think that is the oil warning light. You should probably check your oil immediately whenever that light comes on, as I think it only comes on when your oil level is dangerously low.
Enthusiast Joined Aug 14, '03 From Cleafield, Utah Currently Offline Reputation: 0 (0%) ![]() |
Yeah i had a leak awhile ago and it popped on. I pulled into a gas station and it was bone dry.
Did any damage to your engine occur? -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() Joined Aug 17, '03 From Bangkok, Thailand. Currently Offline Reputation: 0 (0%) ![]() |
If the engine oil level is normal and there is no oil leak anywhere, then;
1. Your oil filter maybe too dirty and blocked(when was the last you had your oil filter changed??). 2. The oil level sensor maybe a bit loose or dirty. 3. Worst case. The oil pump is problably getting too weak to pump the oil up.. if so... bring your car to a garage asap!! |
where is the oil sensor and oil pump located ?
![]() ![]() This post has been edited by veilside: Jun 2, 2004 - 3:08 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) ![]() |
10000 damn, every 3000 dont u love your celi.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Yeah, you really should change your oil filter. It's supposed to be changed with your oil, which should be changed every 3,000 miles.
Your oil filter is problably clogged by now. Changing a new oil filter should solve your problem.
Try not to run the oil filter more than 5,000 miles. It's bad for the engine as all the untrapped dirt are being circulated and accumulated inside the engine. |
![]() Enthusiast ![]() ![]() Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) ![]() |
if you are running good oil and using a good oil filter you can run 6mo. or 6k miles. That's the recommended drain cycle for the amsoil that i use and it works fine. With a synthetic oil it has enough detergents in it to last that long coupled with a good filter wich usually consists of three different types of filter media. It's expensive though. About $15-20 for the filter and $5-10 a quart, but hell we only need 4 quarts.
What kind of filter are you using? I use Toyota OEM filters, which are proven to be excellent in tests for all cars(Some domestics use Toyota/Lexus oil filters.), and they cost me $8 or so per filter. ![]() -------------------- New Toyota project coming soon...
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:10 AM |
