> ARP bolt kits, need help,hightly modify engine
post Jun 2, 2004 - 7:03 PM
alex3sgte
Joined Sep 5, '02
From Puerto Rico
Ok,Im just need to know whats the diferent between @Main and Head Arp stud.Wich one is better for one hevely modified 3sgte engine confused.gif
post Jun 2, 2004 - 8:20 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Main Studs: Studs in the block that have a higher tensile strength than the OEM main bearing bolts.
Head Studs: Studs in the block (also with higher tensile strength) that replace the OEM head bolts.
If you're serious about modifying the 3SGTE, do both, imo. Might want to consider a set of rod bolts too, if you want to use the stock rods.
post Jun 2, 2004 - 9:08 PM
alex3sgte
Joined Sep 5, '02
From Puerto Rico
Thanks man,for real I appreciate your help,thanks again Im goona buy both
Lo-Fi Version Time is now: November 28th, 2024 - 6:21 PM
