> tune up (simple things), car n00b
post Jun 2, 2004 - 7:09 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
Im on a mission to restoring my car to near factory condition , as far as I can. And Im going to do a few things soon.
Plugs and Wires, and fuel filter, I think I can manage.
Can someone help with fuel filter placement and how to install a new one.
What other things would help make the car run better and smoother (idle doesnt sound too pretty as seen on the other thread)
I'm also very new to cars (can change plugs and wires pretty easily, change oil, gonna change fuel filter soon with your help)
My friend is going to help me with brakes soon.
How much do timing belt changes usually cost, Im pretty sure I'm due for one of those soon, but i know thats probably the last thing on the list cause its the most expensive.
post Jun 2, 2004 - 7:15 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Tell us how many miles you have and it might help us tell you what you may need done smile.gif
post Jun 2, 2004 - 7:20 PM
LatinKraze
Joined Oct 22, '03
Fuel Filter Change But its for a fifth gen. Might be the same since it has same 5SFE. Please correct me if im wrong. Got it off of celica.net
post Jun 2, 2004 - 7:47 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
post Jun 2, 2004 - 9:03 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Get a new distributor cap and rotor button.
post Jun 2, 2004 - 10:40 PM
ghostdog
From ny to philly
to add to your list:
change your pcv valve
clean the throttle body
post Jun 2, 2004 - 11:27 PM
Tweek
Joined May 4, '04
From Panama City Beach, FL
Yea, the cap and rotor definately if you are doing your plugs and wires. You may also want to do you fuel injectors.
post Jun 3, 2004 - 6:08 AM
hyp3rk1d
Joined Sep 22, '03
how do you clean the throttle body??
post Jun 3, 2004 - 6:25 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
yeah , I dont even know what a PCV valve is so I think thats over my head frown.gif
post Jun 3, 2004 - 6:40 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
how would I know if I needed a timing belt change?
post Jun 3, 2004 - 1:02 PM
spunky393
Joined Apr 22, '04
From illinois
timing belts are just normally changed every certain milage, i can't really think of it, but someone probably knows. Hyp3R, just get a tooth brush, some brake cleaner, or some really strong cleaning agent, and spray the tooth brush. Then you open up the butterfly on your throttle body, and scrub scrub scrub (the inside and the butterfly).
post Jun 3, 2004 - 2:17 PM
FoREpLayAX
Joined May 2, '04
From HTX
where exactly is our pcv valve?....i guess its bout time i changed that
edit: nevermind....found it
This post has been edited by FoREpLayAX: Jun 3, 2004 - 3:49 PM
I am ever so thankful for the 'Ignore User' capability on this forum.
post Jun 3, 2004 - 3:20 PM
hyp3rk1d
Joined Sep 22, '03
thanks man.. how much do timing belts run for?
post Jun 3, 2004 - 3:21 PM
Guest_Jason_*
Timing Belts are cheap, installation costs are expensive. Good luck.
post Jun 3, 2004 - 3:24 PM
hyp3rk1d
Joined Sep 22, '03
ok what cleaning agent should i use?? ne suggestions besides brake cleaner??
post Jun 3, 2004 - 5:33 PM
spunky393
Joined Apr 22, '04
From illinois
haha, i actually don't have any other suggestios because i use break cleaner to clean everything mechanical wise, haha, great stuff, you would love it. Don't get me wrong, but i think when i replaced my timing belt, 80,000 i think is the suggested time, it cost about 600, supplies and labor. Would've done it myself, but i didn't have the time.
post Jun 3, 2004 - 7:28 PM
Snarfer
Joined Dec 2, '03
From Virginia
Timing belts are cheap and 96+ (I think) you may need to get a tensioner, maybe 50 bucks or something. It can be very hard to do, on an accord you need to take the top end timing covers off which isn't too bad, just removing alternator and such. the hard part is the lower end, have to jack up the motor, take out the front mount, and lower it slightly to get clearance. That's just on an accord, dunno how celicas are.
post Jun 3, 2004 - 9:37 PM
Guest_Jason_*
Boo! Timing belts suck.
post Jun 4, 2004 - 2:47 AM
jontechie
Joined Oct 25, '02
From London- England
Had all my belts done about a month ago. If your doing the timing belt get all
the others done at the same time (alternator, power steering). If I'd taken
it to a dealership the cost would have been around a grand or more, luckily my
cousin is a mechanic. Expect a minimum of 5hrs work (GT4 engine bays packed to
hell) ,if a standard GT a little less. Oh and you'll have to by a timing belt tensioner
just as a precaution if the old one is damged during removal.
post Jun 4, 2004 - 4:40 PM
spunky393
Joined Apr 22, '04
From illinois
you don't need to replace your pvc valve unless you pull it out and it doesn't rattle when you shake it. If it rattles, it's fine.
Lo-Fi Version Time is now: February 23rd, 2025 - 1:31 AM
