> QUICK QUESTION..., Will ST185 Brake Discs Fit My ST202?
post Jun 9, 2004 - 5:13 AM
mush
Joined Feb 16, '04
From England, UK.
just a very quick question and i havent had a chance to look up on this one. i can get a pair of very cheap grooved/drilled front and rear brake discs advertised for ST185... any idea if ill be able to use these on my ST202?
thanks,
mush.
post Jun 9, 2004 - 1:27 PM
mush
Joined Feb 16, '04
From England, UK.
post Jun 9, 2004 - 3:18 PM
I'm 95% sure they wont.
post Jun 9, 2004 - 4:44 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
I got my rear discs from a 5th gen celica. They fit fine. I don't know how this applies to the all-tracs, the parts didn'tsay what kind of car. Just a 5th gen
Jeremy
post Jun 9, 2004 - 5:56 PM
I would imagine the ST185 had bigger braking system.
post Jun 9, 2004 - 10:52 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
No this won't fit, you can use a 5th gen gt disk's but not a GT4's, it has bigger disk's. You may be able to put in the whole assembly with some customer work though.
post Jun 10, 2004 - 12:36 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The 1st and 2nd gen GT-4/alltrac rotors will probably fit. There is no significant difference between the GT-4 brake system and the 4th gen/5th gen celica's rear brakes. The 3rd gen GT-4 (st205) ones will probably not fit, but the older ones are not any different than even 7th gen models... give it a shot if they're cheap...
Lo-Fi Version Time is now: November 29th, 2024 - 6:22 AM
