> hp and torque gains, fo shizzie
post Feb 19, 2003 - 2:19 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I was wondering if anyone could give me some info on the type of power gains I can expect from an underdrive pully, msd ignition, and hiperground. if anyone has tryed anyof these out, was it worth it?
post Feb 19, 2003 - 2:22 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I think a ASP Underdrive pulley is suppost to give you a 8HP gain.
The others i don't know.
post Feb 19, 2003 - 3:00 AM
94celicaguy
Joined Nov 11, '02
just to let you and everyone else know, aftermarket ignitions are a waste of money unless you really have your car modded. i am talking supercharger, turbocharger modded. your car is only going to take as much energy as it needs. the car is a smart machine. whether you have your stock ignition system or a $400 ignition system, your car is only gonna take as much energy as it needs. just a little tidbit of info for anyone looking into ignition. also a good song now out by r. kelly.lol biggrin.gif
post Feb 19, 2003 - 3:12 AM
95STCelica
Joined Oct 12, '02
From New Jersey
the cams by OBX are good too...
post Feb 19, 2003 - 6:03 AM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (jayi12-15psi @ Feb 19, 2003 - 2:19 AM)
underdrive pully : 1-5hp gain
MSD : depending on which type use. Digital 6 Plus or better use Crane Cams HI6 w/ LX92 coil. MSD Digital 6 : 8 - 15HP Crane Cams: 10 - 25HP . ***
Exhaust : 8 -15+hp
*** depending on A/F ratio, ignition timing, fuel used, plugs, Air filter like Greddy, HKS which passes alot of air flow per cfm.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Feb 19, 2003 - 11:22 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
west-minst, How difficult would it be to install cams?
post Feb 19, 2003 - 5:44 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (jayi12-15psi @ Feb 19, 2003 - 11:22 AM)
No long at all.
If your car have over 100K KM, you should change your timing belt the smae time.
Once purchases (256-264 degree), just swap them. A repair manual can help you.
Before you remove the the belt and cams, you have the choice for TDC or BDC OR turn the crank until the cams indicator matchs up the indicator on the head.
Again, a repair manual or someone who have done it before can give you exact detail.
But once you know what you are looking for, you are good.
post Feb 19, 2003 - 6:56 PM
edo17982
Joined Dec 21, '02
From Italy
hey west, what do you think about products offered on http://www.importperformanceparts.net/ ?
Thay offer many perf parts for 7AFE at a not expansive price....
post Feb 19, 2003 - 7:40 PM
Charlie97L
From North Bethesda, MD
QUOTE (edo17982 @ Feb 19, 2003 - 4:56 PM)
that's mostly internal parts. don't waste money buildng the 7afe unless you are going to go turbo. it's an economy engine, cams and other parts normally good on an NA really won't help that much.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Feb 19, 2003 - 11:19 PM
west_minist
Joined Oct 27, '02
From Barbados
I agreed with Charlie on this one.
You see, if you had the 3SGE swap in you car, I would tell you to go for it.
I do not know, but there is a 7AGE which is a 4AGE head on a 7AFE block.
Research that.
I would advice you to try swapping in the 3SGE or 3SGTE. Greater benefits can be attains there.
This post has been edited by west_minist: Feb 19, 2003 - 11:21 PM
post Feb 20, 2003 - 5:58 PM
chris102984
Joined Feb 18, '03
From Ohio
ohhh the 7age... what ive always wanted to do, but never had the funds to do so. anyways... you'd probably be better off putting in a 3sgte or if you have a 7afe... a 4agze would be quite beefy. im more apt to talk about the a series engines since ive got a p.o.s. corolla and ive read quite a bit on what engine swaps/cross-breeds would be the best using the available mounts.
post Feb 20, 2003 - 11:45 PM
FallenHero
Joined Dec 26, '02
From Alabama
Charlie, I have a question. You seem to have knowledge of the -a- series engines, so...
Ok, I have a thought. It would takes loads of cash to get a 4agze in my car. It would take even more to 3sgte it. Now, It is also expensive to turbo it with 3s parts. BUT, I wonder if it's possible to get a 4agze super charger and find a way to mount it to my 7a. What do you think?
Jon
post Feb 21, 2003 - 12:20 AM
PaulGT
Joined Nov 8, '02
From Bel Air, MD, USA
I am interested in gettin a pulley to...is it a hard install?
post Feb 21, 2003 - 1:10 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
Thanks alot for the responses guys, west minst, do you know if the haynes manual has information on replacing the cams?
post Feb 21, 2003 - 1:13 AM
Charlie97L
QUOTE (FallenHero @ Feb 20, 2003 - 9:45 PM)
Jon
no i don't think it would work. the belts on the 4agze just won't line up i think... it would end up costing as much as a 3sgte swap, and be a pain in the ass, and probably wouldn't be reliable.
1994 Lexus ES300
1989 Supra Turbo
post Feb 21, 2003 - 12:04 PM
FallenHero
Joined Dec 26, '02
From Alabama
My thought was to get the charger for a low price off of an old Mr-2, (or go on 4agze.com and find somebody who did a turbo swap.) Mount it in some outlandish way, and run a belt to it. (which with the left engine mount where it is, would be a bit*h). What kind of boost did the 4agze SC have?
post Feb 21, 2003 - 5:21 PM
chris102984
Joined Feb 18, '03
From Ohio
i was under the impression that you could swap the head off a 4agze along with the supercharger on a 7a block. problem is boost cant go insanely high, the connecting rods and crankshaft cant take all that much stress, but i read up on a 7agze... biggest concern is transmission, you need a beefy clutch to handle all the torque.
as for just taking the supercharger... doubt that'll work, plus the boost may be too much without lower compression pistons meant for the forced induction.
This post has been edited by chris102984: Feb 21, 2003 - 5:22 PM
post Feb 21, 2003 - 11:39 PM
FallenHero
Joined Dec 26, '02
From Alabama
the 7-a has a 9.5:1 cr. It could handle boost up to about... 9ish. I realy don't think a factory supercharger would be anywhere near that though.
post Feb 22, 2003 - 1:33 AM
chris102984
Joined Feb 18, '03
From Ohio
what ive read is it can take 5 or so reliably... but i figure if you're gonna buy the supercharger... may as well toss in the extra cash, get quite the beastly engine. ive never done it due to lack of money & ive got an automatic... that'll die quite fast & a manual conversion is just too much a pain in the arse
post Feb 23, 2003 - 11:21 PM
FallenHero
Joined Dec 26, '02
From Alabama
You could most likly find a SC from an older 4a for $200. It wouldn't be That hard to bolt it up, and it would give an easy 30Hp. Sounds quite cost effective.
Lo-Fi Version Time is now: February 17th, 2025 - 12:25 PM
