> ST205 3SGTE Pistons, Forged Piston Choice
post Jun 14, 2004 - 12:48 PM
racingmcfly2
Joined Jun 14, '04
From Wimborne Dorset England
Hi there,
Im new to this site, just found it today and what a site i must say, its just what ive been looking for!!!!!!!!!
Anyway im wondering if anyone can help me work out what pistons i need to run in my GT4 ST205. Its recently droped the rings on pistons 2+3, so im gonna need to get it rebored. Ive been looking at getting some JE pistons for it but the cheapest i can find them for in the UK is £580 for the 86.5mm
Looking on ebay and other american sites im looking at $500 for the same pistons which works out at about £270. quite a significant saving. However trying to work out which ones i need is a bit confusing
Part no 162109 which i have found on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33617
tells me that the Compression ratio of this piston is 9:1, but the standard celica ST205 is 8.5:1
But this piston is listed for the MR2 so does this mean that the valve chamber is a different size or are there different pistons with the same code at different CR
Any help on this would be greatfully recieved
Cheers Olllie
post Jun 14, 2004 - 2:02 PM
Lar-
Joined Aug 17, '03
From Bangkok, Thailand.
You can use a thicker engine head gasket to reduce the compression ratio.
Your stock head gasket is 1.2mm.
I think you can ask your mechanic to calculate, with the new JE 86.5mm Pistons set, how much thicker should the new engine head gasket be in order to bring down the CR to 8.5.
post Jun 14, 2004 - 3:17 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
http://www.fensport.co.uk/ has some...
and if its only the rings, and there is no block damage, you can just get the standard size 86mm pistons from (JE)fensport for £500.00... you;ll save money because you wont have to bore the block.
Mina
post Jun 15, 2004 - 1:03 AM
tufy
Joined Dec 3, '03
From Cyprus
i am planning to buy jun ($1219) internals for my st 205. there is not too much choises.
hks, jun and je. hks is also good brand and cheeper then jun ($ 998)
there prices are from japan. no delivery included.
also tte have pistons but they are most expensive internals.
post Jun 15, 2004 - 7:19 AM
racingmcfly
Joined Jun 14, '04
Does anyone know the CR of the MR2 turbo is.
post Jun 15, 2004 - 8:15 AM
Joined Jan 27, '03
From st.lucia
i just put in ross forged pistons, the c.r is 8.5-1 and they came with rings and pins. the best thing is that they cost only usd $379.00, u can get them in 86mm or 86.5mm. hope this helps
post Jun 15, 2004 - 8:21 AM
racingmcfly
Joined Jun 14, '04
1900? Where abouts did you get hold of the ROSS pistons? Spounds good. Where they of a good quality?
post Jun 15, 2004 - 5:28 PM
boosted_K2
Joined Aug 30, '02
From Michigan
i have those JE forged pistions in my car, you need to slightly bore out the cylinders, all in all im very happy with them.
No but I don't buy it
Cause I'm...
post Jun 16, 2004 - 7:24 AM
Joined Jan 27, '03
From st.lucia
if your block is not damaged, you can get 86mm pistons so you don,t have to bore your block. the ross pistons are crafted very well and u can't beat the price which includes rings and wrist pins. u could try ross racing pistons,625 s douglas street,el segundo ca 90245 tel. 310 536-0100. ask for joy roble.
post Jun 16, 2004 - 7:54 AM
ian_s
Joined Feb 3, '03
From Essex, England
racingmcfly, get on gt4oc.com !
This post has been edited by ian_s: Jun 19, 2004 - 11:08 AM
post Jun 16, 2004 - 8:18 AM
Magic
Joined Mar 30, '03
From Cyprus
I`m fan of JUN products, cuz it happents to see some really FAST and RELIABLE cars with JUN internals.
HKS its also nice......ehmmm....i think you should make your choice in 1 of those 2.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:05 PM
