> Spare Tire Question, Can I?
post Jun 17, 2004 - 1:22 PM
hermo69
Joined Dec 7, '03
From CANADA
Hey guys,
Sup y'all! I've got 17's on my ride and lowered with eibach sportlines. Now, I have a 14" Spare which i took out to put my subs in but i kinda want a spare just in case. Can I still use that spare if the tire makes the wheel the same size as the 17 or will that mess things up? For all you guys out there with the same situation, what did you do?
Any help or ideas is greatly appreciated..........
post Jun 17, 2004 - 1:31 PM
You can still use your spare, just make sure you don't drive long with it on. Also, don't drive too hard or very fast with the spare on. I've got 17" wheels on my car and I had to drive with a spare when I blew out a tire a couple months ago.
Oh yeah, make sure your spare has air in it. I found out that mine didn't once I had it bolted on and lowered the car back down.
post Jun 17, 2004 - 5:58 PM
Paule
Joined Mar 30, '04
From Australia - Brisbane
Hey,
I got what is called a space saver tyre, it is half the width of a normal tyre and fits flat with the floor in the celica, so my subs fit flat over the top. It is the same diameter as the normal ones, so it is fine to use. You can only use it for a very short time thou, just to get to the tyre shop, coz it is hard to drive with. I don't know if you have them where you are thou, I'm in Australia. I haven't had to use it yet, so I don't know how good they actually are!!
Anyway.......good luck!!
Paule
This post has been edited by Paule: Oct 22, 2004 - 3:43 AM
post Jun 22, 2004 - 10:14 PM
97GTinKC
From KC
I would put the space-saver on the rear and use 2 of the regular wheels on the front if I had more than a couple of miles to go (assuming the front was the one with the flat) its more work, but safer, the front has more weight, and its not good for the transaxle to have diff size tires, differential gears would always be turning like you were always in a turn. .
Lo-Fi Version Time is now: December 3rd, 2024 - 5:27 PM
