> gauge cluster lights out
post Jun 18, 2004 - 2:50 PM
celicakid
Joined Nov 13, '02
From Ontario, Canada
if n e one could help it would be much appreciated. the lights on my gauge cluster have all gone out, so have the lights on my climate controls, ive checked all the fuses and they seem fine. if n e one has had this problem please let me know what u did. i hope its not a wiring problem and has an easy solution, everything with the displays are stock and i havnt messed with them yet
post Jun 18, 2004 - 3:21 PM
Negative
Joined Apr 28, '04
From Houston, Texas
I ahd this problem with the my '86 GTS. It turned out to be a burned out dimmer switch and associated wires. I went to a junk yard got a dimmer with wires for about $5-10, replaced them and never had anymore problems after that. I don't recall if the climate controls are in that dimmer loop, so I don't know if yours is the same problem or not. I'd say check the dimmer for schorch marks and the wire insulation for burns. Let me know if I can be of further help.
post Jun 18, 2004 - 3:24 PM
Did you take apart the dash or anything? If you disconnect the dimmer switch, the dash lights no longer work.
Also, it's happened to people before...make sure you don't just have the dimmer switch turned all the way down. wink.gif
post Jun 18, 2004 - 6:28 PM
RedSunCelica
From San Diego CA
this happened to me to for some reason if your hazard lights are disconected from the back of the panel none of the interior lights work smile.gif dont ask me cause sometimes when your working on a car you forget to plug in a few things smile.gif
post Jun 18, 2004 - 6:53 PM
QUOTE (RedSunCelica @ Jun 18, 2004 - 4:28 PM)
post Jun 18, 2004 - 9:37 PM
fastgt
Joined Feb 13, '03
From California
my harard switch got disconnected and i was going crazy for three days trying to figure out what the hell happend...i felt so dumb afterward
This post has been edited by fastgt: Jun 19, 2004 - 2:22 AM
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
Lo-Fi Version Time is now: November 25th, 2024 - 1:24 AM
