> Front Speakers
post Jun 28, 2004 - 1:48 AM
Wolfgang
Joined Jun 11, '04
From Shoreham-by-Sea UK
I wonder if somebody here knows the size of the front speakers. What sort of speakers will fit without mods? I'm planning to buy a set of Kicker components.
Cheers!!!
post Jun 28, 2004 - 2:10 AM
Yota
Joined Feb 27, '04
From Illinois
I am told that 6 1/2 works. But I know some modifications need to be worked out. Let me know if you find out any useful info!!
post Jun 28, 2004 - 9:49 AM
acenova
Joined Dec 21, '03
From Portland, OR
There's a how to on putting 8" subs in there. Personally, the housing unit seems big enough to me to be able to actually screw the 8" right in w/o mods. I have 6 1/2's up front(as are standard) but I had to buy/make my own mod for those. It's not hard though. As far as wiring, no mods required unless you're putting in that 8" sub. wink.gif
post Jun 30, 2004 - 10:20 AM
95BlueGT
Joined Aug 30, '02
From Austin Texas
Edited: Due to my stupidity.... frown.gif
This post has been edited by 95BlueGT: Jun 30, 2004 - 1:21 PM
post Jun 30, 2004 - 10:31 AM
shid
Joined Jan 8, '04
From LA
DIameter of the stock speakers is 6. 3/4th. THATS what it is, and dont listen to anyone else, do a search and you'll find a much more useful faq on this. It's incorrect info like this that makes aftermarket hard for our cars.
Now, you CAN replace that 63/4 with any size pretty much, long as you have a bracket. 6-3/4 won't require a bracket.
post Jul 3, 2004 - 5:59 AM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
Look at the how-to i posted... It shows you what you have, and what to do if you are going with 6.5´s. The diameter of the CONE of the speaker may be 6.75, but the fact remains that with the metal plate that surrounds the stock speaker, the hole is around 8". I am pretty sure that even with a 6.75, you will need to make a bracket... shid, did 6.75´s fit into your car with no modification?
post Jul 3, 2004 - 12:04 PM
Jabberwock
Joined Sep 22, '03
What about the rear speakers? Looked at what people said about that one and I am still not sure if its 6.5 or 6.75...
post Jul 4, 2004 - 4:33 AM
celimanST
Joined Nov 15, '03
From mississippi
You will need a mount bracket I have been told in the past that you don't need one well those people are full of **** I had to make one. I was expecting the install of my components to go easy uuummmm no it didn't happen than.
The diameter of the stock speaker bracket is 8" I measure and that is what it is.
William
post Jul 4, 2004 - 11:12 AM
shid
Joined Jan 8, '04
From LA
The stock speaker bracket holds a 6.75 speaker
post Jul 4, 2004 - 12:15 PM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
OK 2 things...
1) for the front, in my celica and many others, the stock speaker bracket does NOT hold 6.75 OR 6.5 speakers, even though most speaker magazines say otherwise... Shid, you must have a different model speaker bracket or something.
2) for the rear, 6.75´s work fine. I personally installed all of my speakers. I should have done a how-to, it was fairly painless once you get to the brackets... To get to the brackets, however, you have to remove both back seats and a crapload of panels.
Any other questions you can contact me. The best thing to do is figure out whether or not ur speaker brackets in front are the same as pictured in my how-to and that of the "how to install 8" speakers in front"... If so, u gotta make a bracket...
Shid, please take a picture of the bracket that you have in front... i´m curious.
Ed.
post Jul 4, 2004 - 12:22 PM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
QUOTE (shid @ Jun 30, 2004 - 8:31 AM)
Another thing, Shid... please be careful when you make statements like this... a bracket/ adapter IS needed for most applications that i´ve heard of... Since I´ve only worked on my 94, I cant say that ALL will need an adapter, but to say that 6 3/4 will fit in all celicas is "what makes aftermarket hard for our cars."
I´m not trying to flame you Shid, I have much respect for you. Make sure you are informed before telling people to "not listen to anyone else."
Ed.
post Jul 4, 2004 - 12:27 PM
shid
Joined Jan 8, '04
From LA
I'll take a picture next time the door is off. My 6.5s are in the 6.75 stock speaker bracket just fine.
post Jul 4, 2004 - 12:52 PM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
Good stuff, email me the pic when u get the chance.
Ed
post Jul 4, 2004 - 1:09 PM
shid
Joined Jan 8, '04
From LA
(one of them used to rattle like hell when the door closed tho- I solved it with a large washer)
post Jul 5, 2004 - 1:28 AM
exxtractor
Joined Mar 31, '03
From BC
Shid my 94 ST will hold an 8" speaker without modifications. 8" is the stock speaker size for my car. You need an adapter to mount anything smaller than 8". Many European cars come with 20cm stock speakers which is approximately 8". There is a guy registered on the site fromt he UK who installed 8" pioneer speakers mounting to without an adapter. So stop telling people you're right and everyone else is wrong. You'e only been registered since January, some of us have been here a few years.
post Jul 7, 2004 - 12:24 PM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
Hey, Ive owned 2 Sixth gen Celicas in my ripe old age of 20 and heres some ideas I can share....
My first was a 94 ST w/o power locks or windows. The speaker hole appears to be 6 1/2 to 6 3/4". The problem I had with Alpine Type R 6 3/4 components is that the mounting depth is too deep to fit when the window was rolled down. So what I decided to do is cut out the speaker grilles and then drill holes for the speakers to mount to the door panels themselves...not behind them like stock. It really worked great and looked awesome.
Heres a pic from my cardomain page
Heres the whole page
My current one is a 95 GT 5 speed (sooo much more fun biggrin.gif ) This one has power locks and windows, and the speaker size measures out to 8" with the ridicuously thick plate that is around the stock speaker. I found an actual 8" (210mm) midrange and tweeter system made by Focal. Problem is its extremely rare, Its a 210EX in the discontinued Typhon Line. If you can find it however, I highly recommend them because they have incredible bandwith and can provide bass if you do not plan on having subs. These things fit like a glove in the stock speaker bracket. The mounting holes do not line up...but because it was so extremely tight, i decided to just use some silicone sealer to hold the woofer in place. I havent gotten around to posting pics of my new car but will come soon!
The bottom line is that if you do not have power controls...the stock speaker bracket is about 6 3/4". If you do have power controls, it is closer to 8". I do not recommend putting free air subs in the front doors, because the front stage is meant to be reserved for the midrange and shimmering highs of tweeters, not bass. If you cant come up w/ a 8" midrange, then look at the "how to" on making a bracket adapter to go from 8 to 6 3/4. Hope these ideas can help you all out
post Jul 7, 2004 - 12:30 PM
shid
Joined Jan 8, '04
From LA
QUOTE (exxtractor @ Jul 5, 2004 - 6:28 AM)
Pointing out that you've been here longer doesn't do you any good when you don't know what you're talking about, as you've just demonstrated. So what if I've only been here since January? I've obviously spent more time on this stuff than you. The above post is correct. The stock speaker size is 6-3/4s, with a huge bracket/ring that makes it fit in an 8 inch space.
post Jul 7, 2004 - 12:31 PM
Hopefully my new Pioneer REV coaxials will show up today. If so, I'll take pictures of the inside of my door panels and post them up.
post Jul 7, 2004 - 1:46 PM
mr_dude
Joined Feb 16, '04
From San Diego
Heh, take it easy on him, he's from Canada. He probably doesn't know non-metric units very well. Or maybe they shipped 8"s to all the Canadian dealerships and us Americans only got 6 1/2s. Speaker size, of course, made no difference with my purchase because I needed to mount them specially anyway. Even though the speakers I bought were Fujitsu, like the ones that came in the car originally. Yarg.
post Jul 7, 2004 - 2:17 PM
shid
Joined Jan 8, '04
From LA
No.. he's just confusing the bracket for part of the speaker; so that 6-3/4ths turns into an 8 inch.. when it's really a 6-3/4ths with a giant bracket around it...
Lo-Fi Version Time is now: February 22nd, 2025 - 8:20 PM
