> JDM Headlights, wiring harness
post Jun 28, 2004 - 8:44 PM
koan
Joined Mar 21, '04
From Knoxville, TN
I recently poked a guardrail with my car and will need to buy new headlights frown.gif . I really want to buy HID. Do these require a new harness to install? If so where can i get it. thanks
post Jun 28, 2004 - 8:47 PM
Your topic says JDM, and then you say HID. JDM lights do not come with HID, thats another 350-450 and its a conversion kit.
The Projectors will run you around 450; 800 for the complete 4 piece set.
post Jun 28, 2004 - 8:53 PM
Outsider
From Kelowna, BC
The projectors do take different bulbs which will require you to replace the bulb plugs on your harness.
1994 GT-S (BEAMS) swap complete
post Jun 29, 2004 - 2:35 PM
stelica85
Joined Jan 16, '03
From Wichita KS
yes i just recently did this myself you need a new harness i used a harnass from a 80 style chevy truck and it works fine.
post Jul 9, 2004 - 10:47 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
you can buy the plugs that you need at walmart for $5 and it is really easy to do
look in the isle where all the car lights are at
post Jul 10, 2004 - 2:17 PM
macavely
Joined Nov 4, '02
just came from pepboys and they have coversion pluse... they are 15 bucks each..
on end end it's the plug for stock lights.. on other other end its the pulg for the new lights you want to intall.. they hadd about 10 diffrenet ones.. you should try checking that out.
Lo-Fi Version Time is now: December 3rd, 2024 - 3:59 PM
