Camber Adjustment with Eiback ProKit Springs? |
Jul 3, 2004 - 11:17 PM |
Enthusiast Joined Jul 3, '04 From So Calif Currently Offline Reputation: 0 (0%) |
Has anyone installed the Eibach ProKit springs and, if so, did you need to install the alignment kit to adjust your camber? How about with the TRD springs? Thanks.
Jul 4, 2004 - 5:52 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
I have Pro Kit springs on my '95 ST. Did not need to install a camber kit, crash bolts, or make any modifications to the strut housing to stay within Hunter's camber specs.
Jul 4, 2004 - 6:31 PM |
Thanks for the info. Did you also change your shocks? If so, what did you get?
Jul 5, 2004 - 9:56 AM |
Changed my struts at the same time with Konis. Satisfied overall; I would like a little less wheel gap... No big deal though.
Jul 6, 2004 - 3:18 AM |
Enthusiast Joined Feb 16, '04 From San Diego Currently Offline Reputation: 0 (0%) |
Eibach Pros and KYB GR2s, didn't need alignment kit, but definitely get aligned.
Jul 7, 2004 - 2:46 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Eibach Sportlines and stock struts - no modifications needed. I'd like to have a lower front end though - the back seems like it lowered more but is still slightly higher than the front. Sportlines should be like the Prokit but with .5" more drop.
Lo-Fi Version | Time is now: November 24th, 2024 - 6:53 PM |
