V6 Solara tranny installed |
Jul 5, 2004 - 10:31 PM |
Enthusiast Joined Jan 15, '04 From New Berlin, WI Currently Offline Reputation: 0 (0%) |
Well I started out by posting here like 9 months ago about what to do about axles for this tranny swap and I bought the parts for the MR-2/Alltrac hybird axles
Then to get the engine mounts to fit correctly I ordered the 3 brackets that bolt to the tranny for the engine mounts from Fensport in europe from a ST205. part numbers front-12311-74160 rear-12321-74310 driver-12325-74230 and i also got the one to the block passenger-12315-74130 Then to get proper fitment I ordered throu TRD the ST205 engine mounts, all 4 of them. Which took 11 weeks to get. Then I did some research to find that the ST205 and the US ST204 have the same shift cables and the same bracket that bolts to the tranny for the shift calbes. So I took my stock bracket and bolted it to the Solara tranny and it fits perfect. The only problem I ran into is the rear mount with the St205 stuff moves it to the driver side a little which now the factory bolt doesn't fit so i had to go to the hardware store and buy a shorter bolt to fit in between the bracket and the crossmember where the power steering rack is. That cross member is different on a ST205 but the one that goes from the front of the car to the rear is the same on a ST204 and a St205. And this is what it looks like installed |
Jul 5, 2004 - 10:36 PM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Is that a 3sgte? cus I have no clue what you hooked the tranny up to.
Jul 5, 2004 - 10:49 PM |
Yes it is a 3S-GTE.
Jul 5, 2004 - 11:02 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
Yep 3SGTE...with tubular intake and exhaust manifolds..Those are freakin nice....I heard the tubular intake manifold can increase up to 100hp to the crank.
3 inch dp, huge TB, and don't know what kind of turbo... rm2932 CAN I have it? |
Jul 5, 2004 - 11:06 PM |
Enthusiast Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
yea man, this is one of the nicest engines i've seen in a celica. want to build one for me?
Jul 5, 2004 - 11:12 PM |
WIll the tubular intake manifold fit on the 5sfe? I know all 3s exhaust manifolds bolt right on..
Jul 6, 2004 - 12:11 AM |
RM, is your car operational yet? I have read other posts of people who have done the solara tranny swap who say the gears are very tall for the 3sgte and torque response suffers. What was your experience? Also, did you add an aftermarket LSD?
Jul 6, 2004 - 7:18 PM |
Yes, I have a custom race Spec ATS diff. The car is not running yet. i still have to finish up my fuel lines, IC piping and some other small things in my spare time. I hope it will run in about 2 to 3 weeks. As for the gearing the Solara tranny (E153) and the stock GT tranny (S54) have very similar gearing. I had figured it out that 1st, 2nd and 3rd should be all about within 1 to 2 mph of the other tranny at redline. 4th and 5th are slightly taller but not by much at all. I think I firgured at 9000 rpm in 3rd gear the Solara tranny about 115 MPH and the stock S54 would have been at 112.5. And for torque response I do have a 2.2 liter since I stroked the 3S with a 5S crank so the motor before felt really good. |
Jul 6, 2004 - 8:12 PM |
But you can't run the 5sfe at 9000rpms right? so whats the comparison to?
Jul 6, 2004 - 8:21 PM |
Enthusiast Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) |
WOW! I love that engine. Nice work. Good job on the tranny swap too.
Jul 6, 2004 - 10:20 PM |
I only have the 5S-FE crank in a 3S-GTE engine. And the compression ratio is 8.4 to 1 |
Jul 6, 2004 - 10:28 PM |
Wait, you can run the 3sgte at 9000 rpms? ahh nvm
Jul 6, 2004 - 10:36 PM |
wow, nice setup. and i thought my normal 3sgte swap was cool ...lol
Jul 12, 2004 - 4:49 AM |
Enthusiast Joined Jul 23, '03 From newport news virginia Currently Offline Reputation: 0 (0%) |
so you have a st205? because i am going with the v6 camry transmission in my swap but if perhaps you have a stateside celica then this article will be very helpful to me....
Jul 13, 2004 - 3:41 PM |
hey guys I was wrong on something. The shift cable from a US GT celica and a ST205 are different part numbers. The ST202 and a ST205 are the same. So I had to make a collar to get my shift cables to work for time being but I am ordering ST205 shift cables. Just wanted to post that.
I just primed my oil system and am waiting for my gear lube from ATS to start the car. |
Jul 13, 2004 - 5:15 PM |
Enthusiast Joined Sep 23, '03 From Miami,FL Currently Offline Reputation: 0 (0%) |
wow very impressive rm...cant w8 til u get the car running because if you do get ready to be bombarded with my questions lol
Jul 18, 2004 - 9:05 PM |
Enthusiast Joined Jun 30, '03 From Columbus, Georgia Currently Offline Reputation: 0 (0%) |
you arent worried about the 5sfe crank being weaker than the 3sgte's? i never heard of anyone trying this...let us know how it turns out.
Aug 5, 2004 - 1:28 AM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
where did you get the intake manifold
Aug 5, 2004 - 2:15 AM |
Enthusiast Joined Jul 24, '04 From Va Currently Offline Reputation: 0 (0%) |
The 5s crank is forged if I recall....Shouldn't be prone to crankwalk or any of those DSM problems... This has to be one of the most badass 3sgte's i've seen. Good work! |
Lo-Fi Version | Time is now: January 9th, 2025 - 12:21 PM |
