> Cigarette Lighter
post Jul 9, 2004 - 1:14 AM
c-note
Joined Mar 23, '04
From RI
Can someone please help... my cigarette lighter no longer works. it worked fine and then i carefully took out some dash pieces to paint and put everything back together and for some reason the lighter doesn't work now. I checked the fuse and everything's ok...also took everything back apart and checked it out... all the connections are fine ...I hate it b/c now i can't use the cell phone charger.
thanks,
-C
post Jul 9, 2004 - 1:26 AM
macavely
Joined Nov 4, '02
did you check the fuse on you car charger
post Jul 9, 2004 - 5:31 PM
c-note
Joined Mar 23, '04
From RI
what do you mean? I checked the fuse on the left under the steering wheel is that the same thing?? if not then what do you mean?
thanks,
-C
post Jul 9, 2004 - 5:35 PM
Negative
Joined Apr 28, '04
From Houston, Texas
He means on the car charger itself. I didn't even know they had one. Check to see if the lighter works as a lighter and not accessory. It should be obviously hot.
post Jul 9, 2004 - 10:08 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
they are really fickel... mine will work one day and not the next...you just have to play around with it...i actually accidentally fixed mine some how by being stupid and putting a gum wrapper in there(not thinkin it being aluminum foil) and crossed the electricity...but i took it right off... and for some reason now it hasn't given me problems since. basically just play with it
post Jul 12, 2004 - 3:45 PM
nicksceli
Joined Oct 24, '02
From pennsylvania
i had the same problem. its probably the fuse on the back of the lighter assemble. it looks like a piece of wire but it actually a fuse. just replace that with a piece of speaker wire and it will work again. its a pain to do cause its so small but that should fix it. let me know if you need more info or do a search cause i remember posting about this before
post Jul 12, 2004 - 10:38 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
mine doing the same and im actually considering putting a push start button there
post Jul 13, 2004 - 12:21 AM
Celicaca
Joined Feb 3, '04
From North Carolina
not to jack but my cigarette lighter will work if i push it in n hold it for a while but otherwise it doesnt pop in then pop out when its finished...it wont pop in. get it? problem?
post Jul 13, 2004 - 4:19 AM
neoklis
Joined Oct 24, '03
From Cyprus
personally i donot use mobile car chargers as they tend to fcuk up the battery of the cell phone.
post Jul 13, 2004 - 6:59 AM
macavely
Joined Nov 4, '02
you can always go to a parts store and get and new socket for 2 bucks.. they do wear out ofter years of use..
post Jul 27, 2004 - 10:42 AM
cadman
Joined Jun 22, '04
mine had the same problem when i bought the car used. i bought a new lighter for 30 bucks from the dealer, and put it in with no tools. it's really easy. the console cover snaps out, and the lighter just unplugs and plug in the new one. gotta have it, ya know?
Lo-Fi Version Time is now: November 28th, 2024 - 6:58 PM
