> FS: 1998 3sgte swapped celica, for sale in my area
post Jul 9, 2004 - 1:51 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
hey guys
there is a 1998 celica that has athe 3sgte in it for sale in my area
PM me for contact info, i will probably go and check it out friday or something like that so i can let prospective buyers on here know some details.
This post has been edited by Coomer: Jul 9, 2004 - 10:10 AM
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jul 9, 2004 - 8:59 AM
Ghost
Joined Sep 4, '02
From South Carolina
hey man, definately please update us on it, i'm interested...but not enough to contact them myself
post Jul 9, 2004 - 10:15 AM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
A Jaws4God Creation...
post Jul 9, 2004 - 1:58 PM
oOoHuY
Joined Nov 12, '03
From h town
verry intrested please post more info asap
post Jul 11, 2004 - 2:24 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
hey guys
i got a bunch of pics of the car
http://www.imagestation.com/album/?id=4286...tulation_page=Y
the interior is clean, the exterior has some dings and some small roblems with paint, expecially around the hood scoop.
i'd say its a perfect 20ft car, any closer and you notice the small things
1991 st185 engine under 66k miles on the clock, less miles on the engine
did the swap 2 years ago
new rear main seal
new plugs,
1.5 year old stage 1 clutch
stock 5sfe tranny(needs fluid change)
2 inch exhaust
factory DP with cat intact
turbo timer
boost gauge
short ram intake setup
greddy type s BOV
factory TMIC
new timing belt
new accessory belts
has AC
TRD oil cap
new battery
3sgte ignitor
no CEL
pretty clean looking swap
engine problems
does not have cold start mode
engine shakes slightly, possible vacuum leak(although boost gauge does not show it) or maybe the cap and rotor need to be replaced(owner did not say if they were new) the shaking can not be felt in the car, and idles steady at 900rpm.
while the shaking could be due to ignition, i have a feeling its because of the vacuum setup, it looks like there were only 3 vacuum lines comming from behind the throttle body, one for the boost gauge, one for the brake booster, and one that went somewhere. there might be a leak that allows unmetered air into the system like the plumbing for the wastegate actuator
could also be bad motor mounts, i only checked one and it looked ok from what i saw. or even a small exhaust leak(im guessing all this because i had the same shake in my celica when it was turboed and each time it developed it was either vacuum or exhaust leak, lol)
one other problem. the car boosts erradically from what i know of the boost of a st185 engine i believe it should boost 8psi or so in pretty much every gear. but in first it hits 12psi, 2nd 10psi, and 3rd only 5psi. car revved freely and made no strange noises, it was too hot to check the turbo for shaft play but im pretty sure its good.
non engine features
leather interior
floor mats
aluminum trim kit silver and black shift boot(matches aluminum trim)
side skirts
sunroof
new head unit
new tweeters
new speakers
sub
i have seen this guy driving the car around my city several times. from what i saw, he drove the car sanely
post Jul 11, 2004 - 5:36 AM
oOoHuY
Joined Nov 12, '03
From h town
I JUST WANT THE ENGINE AND EVERYTHING WITH THE ENGINE
post Jul 11, 2004 - 10:07 AM
hollandceli
Joined Aug 1, '03
From Holland, MI
how much does he want to get for it?
post Jul 11, 2004 - 1:06 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (oOoHuY @ Jul 11, 2004 - 2:36 AM)
i dont think he is going to sell the engine set
he is asking for $11,000
post Jul 11, 2004 - 4:36 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
sweet, i would have rather had teks celi than this one though...
Lo-Fi Version Time is now: November 23rd, 2024 - 7:25 PM
