> Flywheel/Clutch Chatter
post Jul 12, 2004 - 4:46 PM
Does anyone here get clutch/flywheel chattering noises from their car at idle? My car makes a chattering noise at idle unless the clutch pedal is pressed in, and it's worrying me, because it didn't used to happen, and it gradually gets louder as time goes by. frown.gif
I'm running a JUN 9 lb. chromoly-steel flywheel for a AE86 GT-S, and a Clutch Masters stage one clutch kit, also designed for the AE86 GT-S.
Anyone have any ideas as to what might be going on? The thought of a flywheel exploding in a FWD Celica and ending my life or taking off my legs is very scary.
post Jul 12, 2004 - 5:11 PM
macavely
Joined Nov 4, '02
i get chatter.. wone i let go of the clutch pedal to fast when in nutral.. i here it bounce hard too.. but it didn't stat it after the clutch was broken. in.. you shouldn't have to much to warry about.. aslong as you are still getting grip..
post Jul 12, 2004 - 6:57 PM
KAMiX
Joined Mar 4, '03
Coomer I used to get that with my last clutch. Best way to test it is to drive along slowly in 1st... try to listen for the chatter, and then try pulling your clutch pedal towards you with the front of your foot. If you can lift it up a bit and the chatter goes away, you need to get your pedals readjusted.
Main problem I have now with my clutch/lightened flywheel is that when the car is cold the clutch bites too hard, I have to be real careful because the pedal travel is different and it bites straight away when cold...
post Jul 12, 2004 - 10:39 PM
Sev408
Joined Dec 4, '03
maybe your bolts are comming loose therefore the flywheel is vibrating?
are they torqued to specs?
user posted image hows it taste motha f*cka
post Jul 13, 2004 - 12:03 AM
celicaman96
Joined Sep 21, '02
From SLC, UT
Woah! I get that exact sound. Chattering when idling, but if I push in my clutch it goes away and it doesn't seem to be constant. Thought it was just engine chatter (I have 166,000 miles). I had my clutch replaced a year and a half ago, I wouldn't think it'd be going bad already. Sorry that doesn't solve the problem Coomer, just that I've got the same thing.
Edit: No chattering while accelerating or cruising, its strictly when idling...
This post has been edited by celicaman96: Jul 13, 2004 - 12:10 AM
post Jul 13, 2004 - 1:00 AM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
QUOTE (Coomer @ Jul 12, 2004 - 9:46 PM)
Hey, commer
I think these matching for ur 4A-GE is totally wrong!!
How come u get some stuffs ar for older Corolla to fit ur AE111??
It should make a deep damage for ur motor, I suggest to order some suitable for ur engine is the best way.
post Jul 13, 2004 - 2:00 AM
Nah, the AE86 stuff works fine, as long as it's all made for the AE86. wink.gif
post Jul 13, 2004 - 3:59 AM
Slam
Joined Jun 18, '04
From Lincolnshire, England
QUOTE (celicaman96 @ Jul 13, 2004 - 5:03 AM)
I used to get this too, particularly when the engine was cold. After it came back from having a new timing belt fitted there was no more noise smile.gif .
post Jul 13, 2004 - 9:33 AM
celicaman96
Joined Sep 21, '02
From SLC, UT
QUOTE (Slam @ Jul 13, 2004 - 1:59 AM)
...After it came back from having a new timing belt fitted there was no more noise smile.gif .
Ahh yeah, I know I need to replace mine, maybe the sound is a good indication of "Do it now!" wink.gif
post Jul 13, 2004 - 10:05 AM
Hmm...my timing belt was replaced about 10,000 miles ago.
post Jul 13, 2004 - 11:51 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
throw out bearing ?
post Jul 13, 2004 - 11:53 AM
QUOTE (bufferdan @ Jul 13, 2004 - 9:51 AM)
throw out bearing ?
That's what I'm thinking now, after reading up on Club4AG. I'll test that theory out tonight when I'm off of work.
post Jul 13, 2004 - 5:17 PM
celicaman96
Joined Sep 21, '02
From SLC, UT
Hey Coomer, I'm curious how you're going to test the throwout bearing and what happens if in fact it's the culprit. Other than the obvious "replace it" ... Thanks!
post Jul 13, 2004 - 5:51 PM
QUOTE (celicaman96 @ Jul 13, 2004 - 3:17 PM)
I was told that if I just reach down and move the clutch fork while the car is at idle and the sound goes away or changes, then it's probably my throwout bearing. I'm not sure what to do if it is, but I'll post more tonight once I find out more.
post Jul 14, 2004 - 7:24 AM
KAMiX
Joined Mar 4, '03
If the bearing is faulty, you'll have to jack up your car, open your bellhousing and take the clutch assembly appart! Good fun for all! You can buy a new bearing real cheap ($20 AUD over here) from any decent clutch/transmission store - or even Toyota.
If you do go ahead to replace the bearing (or get a shop to do it - $$) It might be worth taking the flywheel and pressure plate and getting them balanced... If this was not done when they were put on it could definately be helping cause the chattering.
post Jul 14, 2004 - 7:32 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
throwout bearing SHOULD ALWAYS be replaced when you do a clutch. It sounds like its the throwout bearing to me though. Clutch chatter usually happens when you go to take off and it chatters against the flywheel. The clutch shouldnt be touching the flywheel when the car is in neutral or the clutch is pressed all the way down.
post Jul 14, 2004 - 10:04 AM
OK, I played with the clutch fork at idle yesterday and it didn't affect anything.
We did change my throwout bearing when the clutch was changed, and the pressure plate and flywheel were brand new.
post Jul 14, 2004 - 11:44 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
wierd!
QUOTE (bufferdan @ Jul 14, 2004 - 9:44 AM)
wierd!
Yeah I know...I wish I could figure this out and get my hydraulic system fixed and have my car running normally again.
post Jul 14, 2004 - 12:16 PM
I was doing some more reading, and it looks like my flywheel or pressure plate may be loose...looks like my plans for the weekend just got cancelled. frown.gif
Lo-Fi Version Time is now: February 20th, 2025 - 4:24 AM
