7ATFE, For all the ST's that are turbo'd |
Jul 15, 2004 - 9:42 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
nik: nice to see my turbo kit is working out for you!!,,, any chance i can get your old exhaust manifold still? i need that elbow part
Jul 15, 2004 - 11:22 AM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
ya i can get it in the mail probably monday or so now do you want the elbow or the hole manifold w/ elbow? on your dyno run what psi were you running?
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 15, 2004 - 1:26 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
bro, do you have modified ignition and injection maps for emanage for 7afte!?!?!??!?! If yes, would ya share them? Thanks |
Jul 15, 2004 - 1:32 PM |
not yet but in a few weeks i should -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 16, 2004 - 3:48 PM |
got it dyno at 5.5 pounds for now results: 131.3 horse 164.2 torque ........ stuff i'm getting done today is a thicker head gasket , 2.5 inch mid pipe (before the cat and connects to the downpipe) install all new belts and with asp underdrive pulley later this month get my injectors rebuilt THIS IS ALL STOCK ( just bolt on turbo)horsepower numbers
Jul 16, 2004 - 6:32 PM |
hmmm after all those dyno runs you must run it on the quarter mile too..
Give us ST owners hope. |
Jul 16, 2004 - 6:59 PM |
Enthusiast Joined Aug 29, '02 From San Diego CA Currently Offline Reputation: 0 (0%) |
164 TQ!!!!! Dude thats is freaking awesome i hope i get those numbers when im down with my set up. |
Jul 16, 2004 - 7:41 PM |
manifold with elbow please!! |
Jul 16, 2004 - 7:43 PM |
nik, your numbers will climb, look at my dyno in my file. that was with map sensor problems..
Jul 16, 2004 - 7:49 PM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Nik, tight numbers! especially the torque. Now do some head work and UPP THE BOOOST!
Jul 16, 2004 - 11:15 PM |
why do you want to change your compression? what boost numbers are you looking for?
Jul 17, 2004 - 9:57 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
he is probably looking to run 12+psi or for more reliability at 10-psi 8psi is just fine for the car, if you have the right supporting mods which i didnt, $90 fuel pump, i waited to buy mine, waited until the engine died(melted piston) my setup is now forkee's setup. i ran 8psi for 6k miles and not until i put the new turbo on and the boost was set at 10psi(didnt mean to) did my stock pump give out causing the damage. i looked inside my engine, everything was still good except the one piston. at 8psi i was faster than a rsx type s from a roll(he blew by me and cut me off so i caught him and passed him) the type s has 200hp and 140?tq or something like that, the torque may be low, but from a roll it doesnt matter much at all. they can run high 14's, and from a roll, you easily get high 14's acceleration out of those cars. and the ST-T was faster than my WRX, which would get off the line faster, but the way i launched my ST-T, it was at full boost before it even moved! incase some dont know, my ST-T was automatic my car was faster than 99-04 mustang gt's that were at most only had exhaust and intake(any more than that and GT's make a lot more power) the ST-T is a very fun car that still got me good milage, like 25mpg. had i changed the fuel pump from the get go, i would still be driving the car and be looking into mods that ad reliability(thicker HG) oh and i never got the chance to dyno tune the car, all that performance i got was before i installed the FMIC that forkee now has, i was running a DSM SMIC. i was waiting till i got the FMIC in to go to a dyno, but my 7afte came to a oil burning end, luckily my warranty covered all the repair costs, lol got a new shortblock for $0 -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jul 17, 2004 - 2:21 PM |
my goal is 8 psi.My engine is on the higher miles side 127,000 i turned it to 7 psi and blow the boot off the bottom of the turbo ( its because the I.C. piping is straight 90 degree angle but the turbo inlet is about 45 degree i cant get a good hold so i order a 45 degree silicone elbow and 2nd day air it should have it monday.When i dyno ran my car before the turbo results: 98.7 horse 128.7 torque after boost (5.5) i gained 35.5 torque and 32.6 horse not bad for that little boost you can diffently tell boost you gotta try it!
Jul 17, 2004 - 2:48 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
I Cant wait until i get my setup all done.. I plan on running 8psi
This post has been edited by hyp3rk1d: Jul 17, 2004 - 2:48 PM |
Jul 20, 2004 - 11:59 AM |
Enthusiast Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
a turboed st = 160 hp
how much hp would a turboed gt be have. |
Jul 20, 2004 - 12:45 PM |
Enthusiast Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) |
I had never modefied the compression ratio and kept it high and ran 7psi boost on it sometimes. I didnt have any help and went on it by myself. My oil pressure was too high also. Intercooler is a must, i went cheap and didnt put one on. My setup would be pretty good for an intercooler because the piping would stay away from the engine and exhaust manifold. Sadly i have run out of money and the project is dead. I have taken it off of the car to spare the engines life.
mine had about 105k on it and my lower boot used to blow off sometimes when i ran it high.
I had a carbon fiber hood to put on my car but the turbo would get too hot in the summer and i was afraid it would ruin the hood. mine was an automatic too, i have heard that an automatic handles the turbo setup better but id like a manual anyways http://www.geocities.com/dustin_az/car.html -------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Jul 20, 2004 - 1:44 PM |
i'm not sure because none of the gt guys have dynod their cars yet i'm going back in about a 2 weeks with the asp underdrive pulley on bigger exhaust and a few other little goodies and see if i cant hit 160+ horse on the dyno -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 20, 2004 - 1:46 PM |
how much skills and money for this kind of project
Jul 20, 2004 - 3:00 PM |
If you want to get the project done without half a$$ing it then you will need to know alot about how a turbo works. Or at least get someone that is working on your car that knows what they are doing. The cheapest way to go is to learn yourself and install the turbo yourself and piece together a kit, but if you dont do it right then you will face the consequences. If you have somebody else do it for you then its gonna cost a lot more and they may not care about how your car is gonna be down the line. I spent 2000 on my turbo but i missed a bunch of things like preparing my engine for the pressure. I should have done more research and had more things done. If i did it correctly, then i would have spent around 3500 but i ran out of money. unless your planning on showing the car, a lot of that money is going to go down the drain and youll never see it again, its an expensive hobby and thats what the people pay for cuz its something they enjoy.
Jul 20, 2004 - 4:19 PM |
It’s actually not that hard.... BUT automotive knowledge helps this is my first import engine I’ve mess with. Before it was ford's 302 V8.a few things you need a Chilton book for the car and Maximum Boost book (eBay or book store) along with a parts list there is one some where on the site it has parts like you need a manifold, drain hose, bov, etc on it. Also there are a few people that know a lot about turboing the 7a or 5s like just to name a few zipstrips, 97scelica, Nik (me),Forkee, itchy (i might have spelled some names wrong so sorry if i did) This post has been edited by nik: Jul 20, 2004 - 4:20 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:17 PM |
