![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) ![]() |
Its done, finaly and it feels so good to drive around now.
Total I spent $1200 Parts list: -Transmission -Shifter -Shift Cables -Flywheel -Clutch Master cylinder -Slave cylinder -New clutch -Clutch metal fluid lines -Rubber clutch line -Flywheel bolts -Pressure plate bolts -Clutch pedal assembly -Manual brake pedal (just the pedal because John told me you dont need the whole assembly) -Tranny fluid -Brake fluid for clutch -Manual Transmission Drivers Side Mount -Starter Relay for Manual -2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm) -Manual ECU (I bought it because I dont want to have a constant check engine light) -Gear Greace Extra parts I have bought: -New clutch kit---$150 (pressure plate, clutch, throwout bearing, clutch tool) -TWM short shift kit----$150 -Shift Boot---$Free(yes its new) -Shift Knob---$Free(yes its new) -New Brake Pads Front and Rear ![]() ![]() ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
Nice. Now you have a CAI without sucking up water!
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
That's awesome!
![]() -------------------- New Toyota project coming soon...
hahhha true never thought of that -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) ![]() |
And you lost weight!!! man we got a new strip the car for track technique!!
Lo-Fi Version | Time is now: February 21st, 2025 - 9:39 AM |
