> Is there a turn signal relay ?, help wit my front bumper turn signal
post Feb 24, 2003 - 10:36 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
well my turn signal only works when im using my hazard or using it
its like mynzeyes' light it only lits up when he's using it
i didn't cut any wires tho like he did wtf
oh i just go new set of 1157's
post Feb 24, 2003 - 11:14 AM
forkee
Joined Nov 13, '02
From So Cal
well i know theres a blinker relay, itsunder the steering wheel column,go under into the footwell and its all the way on the left, small black square with blue print on it, says toyota, 12-01, denso, made in japan , 79007 DOT
dunno bout a turn signal relay....i kno theres a turn signal fuse and a hazard fuse, those are in the fuse cluster under the driver side air vent. hope this helps
post Mar 2, 2003 - 7:20 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
If the relay or fuse was out then they wouldn't even come on when he uses them. Try switching the way you put them in. I know if you get LED 1157 bulbs you have to put them in a certain way or they don't work.
Lo-Fi Version Time is now: November 25th, 2024 - 1:39 PM
