Top of Dash Removal? |
Jul 20, 2004 - 6:53 PM |
Has anyone removed the big soft part of the dash that covers pretty much everything? I need to remove it so that I can hide my alarm brain and run some wires a bit better, and I'm not sure how to go about doing this. Anyone have any tips or suggestions?
Jul 20, 2004 - 8:56 PM |
Enthusiast Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
wouldent it be possible to take out the glove compartment and go up thro there..
Jul 21, 2004 - 12:55 AM |
Enthusiast Joined Apr 22, '04 From California Currently Offline Reputation: 0 (0%) |
what he said. because to take out the dash you have to take out the speedometer, passenger airbag, center console. heres a suggestion... try under the driver or passenger seat. |
Jul 21, 2004 - 1:06 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
haha, under the seat isn't to secure for an alarm man.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Jul 21, 2004 - 1:09 AM |
Enthusiast Joined Mar 31, '03 From Bowling Green, KY Currently Offline Reputation: 0 (0%) |
i took out my dash about week and half ago. very time consuming. first have to take out mid console, cd player, glove box, and the guard under steering wheel.
after you do all that, you have to unplug your wiring harness due to it being connected to the dash. then you will have about 7-8 bolts to take off for the dash. CAUTION: you will have to unplug and remove airbag. You will want to unplug battery and let sit for 15 minutes. Then you won't have any questions about unplugging it. You will probably need to loosen the steering column for you to get the dash out. That big item won't go over the steering wheel w/out you taking those 2 bolts off under the steering column and pulling it down. But the crappiest part is taking apart all the wiring and connecting it all back. I had my car broken into and dash was broken. I replaced it with my dash in other celica. i had to take harnesses off both dashes and exchange them. And I'm not looking forward to doing it again in couple weeks when i start doing st205 3sgte swap |
Jul 21, 2004 - 10:17 AM |
Hmm...that sounds like a lot of work...maybe I'll just keep the alarm where it's located now and find a different way to run wires. Thanks!
Jul 21, 2004 - 10:58 AM |
Are you doing a RHD conversion? -------------------- |
Jul 22, 2004 - 1:10 AM |
no, im not doing rhd
This post has been edited by DoodieHead: Jul 22, 2004 - 1:12 AM |
Lo-Fi Version | Time is now: November 29th, 2024 - 5:24 AM |
