> Audio Installation Impaired, Celica wiring diagram anyone?
post Feb 25, 2003 - 3:56 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
Ok...i just got a kenwood kdc-mp919 and im about to install it. And i figured out that i cant use the factory amp so i have that taken out and am using the harness that plugged into the amp. I've been working for about an hour so all i have are the ground and two power wires hooked up. (black, red, yellow) Thing is...when i turn the car on the deck doesnt turn on. Do i have the wrong wires hooked up or what the hell am i doing wrong? I know i dont have to wire everything to make the deck work...i just want it to turn on so i know i'm getting somewhere. Does anyone possibly have a diagram telling which colors are for what? That would help alot with both this problem and the time consuming process of testing each speaker wire afterwards to see which wire goes to which speakers. So if anyone could help i would love the advice. Thanks alot. Steve-O
post Feb 25, 2003 - 3:58 AM
Doge
Joined Dec 2, '02
By the way..if it matters i have a 97 GT with premium sound system (pretty crappy for premium if you ask me=)
post Feb 25, 2003 - 4:05 AM
Doge
Joined Dec 2, '02
post Feb 25, 2003 - 4:10 AM
forkee
Joined Nov 13, '02
From So Cal
your kenwood deck should have came with a diagram. mine did, if not go to www.kenwoodusa.com and download one for ur particular model. its pretty straightforward. if its not turning on at all once u connect it, make sure u didn't blow the fuse. theres one inside the cabin, and one main one under the hood.
post Feb 25, 2003 - 4:23 AM
Doge
Joined Dec 2, '02
no i have that diagram...what im saying is i dont know which wires from the celica hook to the wires i already know from the deck. They are all different colors from teh kenwood's harness. I dont know which goes to which.
post Feb 25, 2003 - 5:43 AM
3TST
Joined Sep 27, '02
From UK
Best thing to do is check a Haynes/Chilton/... manual.
Having said that, from what I can remember, you have 4 wires: Red, Black, Yellow and Blue.
As a guide:
Red - power (inline fuse);
Black - earth;
Yellow - ?;
Blue - remote (electric antenna).
I don't have details or the manual to hand so I'll check tonight and post tomorrow.
post Feb 25, 2003 - 6:48 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Power Connections
Constant 12+ Blue/Yellow
Switched 12+ Gray
Ground Brown
Power Antenna Black/Red and Pink/Blue connect both wires to the radio's remote wire.
Illumination Green
Speaker Connections
Front/Right + Light Green
Front/Right - Blue
Front / Left + Pink
Front / Left - Purple
Rear / Right + Red
Rear / Right - White
Rear / Left + Black
Rear / Left - Yellow
Please check all of the wires before you make a connection. I am pretty sure these are the right but it never hurts to double check.
Just some advice. Next time buy a wiring harness.
www.sounddomain.com/shop/item.pl?sku=SCOTA02B&vq_id=none
$5 could've saved you a headache.
post Feb 25, 2003 - 7:58 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Yea you should deffinetly get a wiring harness. They will save you any headaches of cutting wires and taping them back up.
post Feb 25, 2003 - 1:33 PM
Doge
Joined Dec 2, '02
Haha...crap...i wish i wouldknown i coulda done that before i cut all teh wires..but thanks anyways guys..that color code helps alot...i'll let you know if i run into any more problems..(be countin on it cause i usually find a way to mess something up) THanks again
post Feb 25, 2003 - 7:23 PM
Doge
Joined Dec 2, '02
QUOTE (AudioFreak @ Feb 25, 2003 - 4:48 AM)
Power Connections
Switched 12+ Gray
Ground Brown
Illumination Green
Speaker Connections
Front/Right - Blue
Front / Left + Pink
Rear / Right + Red
Rear / Left + Black
isnt teh red usually the power...the black the ground...and the yellow the ignition power? i thought that was pretty much the standard...but from what you're saying audiofreak the red and black and yellows go to speakers...are you sure thats how it goes?
post Feb 25, 2003 - 7:53 PM
coolspotz
Joined Sep 24, '02
From Sydney, Australia
Hey doge, I have the same headunit as u....
i m at work atm, but from memory i think audiofreak's color code are correct, will double check when i get home.
post Feb 25, 2003 - 8:44 PM
Doge
Joined Dec 2, '02
Ok thanks alot coospotz...taht would help alot. I just connected all the power wires that audiofreak said but i had two blue/yellow wires so i just fused them together and connected the one power for the deck..should i just use one or should i keep both of them together? So far i have the two blue/yellow wires, the grey and the brown...so that should make it turn on when i start the car right? I hope not cause it doesnt turn on yet. I just checked the two fuses and one was blow so i replaced it..but it still doesnt turn on. So what else do i need to do? Sorry for all the questions guys...now i really wish i woulda bought the harness!!! =)
post Feb 26, 2003 - 8:10 AM
AudioFreak
Joined Dec 19, '02
QUOTE (Doge @ Feb 25, 2003 - 5:23 PM)
The aftermarket radios have standard colors. Red for switch power yellow for constant and black for ground. But the car companys use whatever colors they want.
Radio harness----------------Car Harness
Yellow--------------------------Blue/Yellow (don't know why you have 2. Check em with a meter for 12vdc+)
Red -----------------------------Gray
Black----------------------------Brown
Orange/White-----------------Green
Blue-----------------------------Black/Red and Pink/Blue (connect both wires to the radio's remote wire)
White/Black--------------------Purple
White---------------------------Pink
Gray/Black----------------------Blue
Gray-----------------------------Light Green
Green/Black--------------------Yellow
Green----------------------------Black
Purple/Black--------------------White
Purple----------------------------Red
As far as the 2 Blue/Yellow wires you found. Check both with a meter if they are both 12v constant you only need 1. Just cap the spare.
Check all the fuses. You may have popped one under the hood or in the dash panel. Also check the fuse on the back of the radio.
Check all of the power wires. With a multimeter (no test lights... if you touch the wrong wire with a test light you can deploy an airbag) ground the black probe and touch the blue/yellow you should see 12vdc+. Then the gray wire. It should show 0 untill you turn on the ignition.
Let's us know how it goes. I'm guessing there is a blown fuse somewhere.
post Feb 26, 2003 - 1:08 PM
Doge
Joined Dec 2, '02
IT WORKED!!!! I plugged em in just like you said Audiofreak and the damn thing runs like a champ!!!! THanks alot...i really wish i woulda got the harness but hey...i never woulda learned that way. And I NEVER woulda been able to do it without you guys. Thanks alot...this is the best site ever!!! Speaking of this site...i just checked the member number and its at 997 right now....haha..we should throw a party or something for coomer for having such great success with his site.
post Feb 26, 2003 - 3:52 PM
AudioFreak
Joined Dec 19, '02
This post has been edited by AudioFreak: Feb 26, 2003 - 3:52 PM
Lo-Fi Version Time is now: November 25th, 2024 - 2:36 PM
