usdm swap, has anyone? |
Jul 25, 2004 - 2:39 AM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
ey I was wondering if anyone here has swapped in a 3sgte from a usdm turbo here, I'm sure someone has here. I was wondering if the wiring harness needs to be extended with a usdm 3s, or if any other modifications are necessary.
o, btw, this isn't Jim, this is his friend Mike thanks guys -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Jul 25, 2004 - 3:23 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Yes it does its the same as the JDM 3stge swap, just less HP.
Jul 25, 2004 - 3:38 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
not only less hp but it would be impossible to find one with less then 80,000 miles on it unlike the jdm ones that come with around 40,000 or less.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Jul 25, 2004 - 8:33 AM |
My JDM engine had 45,000. Main reason ppl go JDM its actually harder to find a USDM engine.
Jul 25, 2004 - 9:39 AM |
you dont need to extend the harness. even with a jdm engine.
when i took my 5s out, i cut a hole in my firewall, right behind where the ecu is. that way the cables have a direct path to the ecu. i think this is better then extending, because u dont have to worry as much about those wires coming loose and causing you problems. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 25, 2004 - 11:06 AM |
^ Agreed.
Jul 27, 2004 - 11:42 PM |
Enthusiast Joined Jul 23, '03 From newport news virginia Currently Offline Reputation: 0 (0%) |
hmm some intersting posts her but firstly you can get the jdm ecu and hook it up to the usdm 3sgte to acheive a 25 hp gain you only need to run higher octane fuel. secondly i never knew the usdm second gen 3sgte was set up for a right hand drive....
Lo-Fi Version | Time is now: November 24th, 2024 - 4:22 AM |
