> Failed MOT (uk)_ Help
post Jul 26, 2004 - 3:51 PM
veilside
Joined Sep 28, '03
From UK
had my import SSII mot'ed today but it failed on emissions, CO was suppose to be <0.30% but mine was reading 0.76% which is rather worrying, wat can u guys suggest i can do and what can be the fault thats causing this??? i have a aftermarket exhaust on the car the garage reccomended me replacing this wiv a standard exhaust and it should work, any suggestions to this????
post Jul 27, 2004 - 1:11 AM
neoklis
Joined Oct 24, '03
From Cyprus
Its not a matter of exhasut per say. I had the same problem with my Curren. If all your cats are there and in working condition then the problem is dirty injectors. You can buy Injector cleaner and put in your gas or if you can wait do what i did. Drive it extremely hard for 15-20 minutes and the injectors will clear up.
btw, its always best to take your car for MOT after a service and if you can let your mechanic take to MOT, making this his problem.
Also, you can tell your mechanic to tace out the injectors and clean them, but you must really trust him before you choose this as most mechanic will just mess up your injectors instead.
post Jul 27, 2004 - 2:40 AM
jontechie
Joined Oct 25, '02
From London- England
As Neoklis said, your may have had a decat, did your lambda sensor perform in range, should show up on your emission printout. Some fuel cleaner/ injector cleaners can knock your emissions down,best to go for that route first as its the cheapest, then check for leaky injectors,fuel regulator problems.
post Jul 27, 2004 - 11:54 AM
veilside
Joined Sep 28, '03
From UK
will try some of the fuel injector cleaner first, but if that dont work, any other suggestions????
so wat they saying abt the standard exhaust is b*****s then???
post Jul 27, 2004 - 12:05 PM
veilside
Joined Sep 28, '03
From UK
if it is any help these were the readings for a the fast idle test
CO: <0.30% but was 0.76% - HC:< 200ppm vol read 66pm vol - lambda: 0.970-1.030 read 1.024 which was really marginal i guess
any ideas what the figures may indicate the fault??
post Jul 28, 2004 - 1:12 AM
neoklis
Joined Oct 24, '03
From Cyprus
Man those are almost my currens figures. the problem must be dirty injectorsfor sure, as i understand your cats are inplace.
post Jul 28, 2004 - 8:27 AM
veilside
Joined Sep 28, '03
From UK
yeah cats in place but is it working haha, will get it checked later, well will have some injection cleaner in the car, see if it helps biggrin.gif
Lo-Fi Version Time is now: November 23rd, 2024 - 9:35 PM
