ST converted to GT all wheel disk, I know its been done so help me out |
Jul 26, 2004 - 8:25 PM |
Enthusiast Joined May 1, '03 From Houston , Texas Currently Offline Reputation: 4 (100%) |
I know this has to have been done before I am just wondering what the price and time needed to take my ST calipers and rotors move them to the back and get some GT rotors and calipers for the front. I am very anxious to do this. Help me out
Matt |
Jul 26, 2004 - 8:46 PM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
shouldn'ttake you too long to do the swap. Took me prolly 6 hours total. The hardest part is finding the parts for a cheap price.. Theres a HOW TO in the how to section Jeremy EDIT:
you cannot move the ST calipers to the rear. you have to buy GT rear brakes for the swap. This post has been edited by Jeremy1210: Jul 26, 2004 - 8:47 PM |
Jul 26, 2004 - 8:48 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Why would you want to move your st calipers to the back and put gt's in the front? Why not just put the gt's in the rear, it would be a lot less trouble. You going to have to get the gt rear disc setup off a gt anyway.
Jul 26, 2004 - 9:22 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
You cannot move your ST front rotors and calipers to the rear. Not without removing your parking brake and having to do some fabrication. Like everyone's saying; best to use GT brakes, you won't have to worry about something being dangerous and you can put GT front brakes on your ST at the same time you do the rear if you like.
Jul 26, 2004 - 9:41 PM |
dont all you need is the caliper and rotors?? what is the bake plate??
also will like 00-03 rear break rotors work?? This post has been edited by Digndoug: Jul 26, 2004 - 10:20 PM |
Jul 27, 2004 - 5:21 PM |
Enthusiast Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) |
you need new brake lines brake plate rotors calipers and a bigger master cylinder for the complete swap
Jul 27, 2004 - 9:53 PM |
For the fronts... just the rotors and calipers with all of the associated lines. The rear, you'll need the whole assembly (ebrake cables, brake lines, backing plate, rotor, etc...) Also, I believe (after a bit of research) that the GT and ST use the same proportioning valve... so either one should work just the same. -------------------- "It's ok to be naked girl... I'm an artist!"
Jul 31, 2004 - 1:31 PM |
Enthusiast Joined Oct 21, '02 From Pittsburgh Currently Offline Reputation: 0 (0%) |
Then you wouldnt need a new master cylinder?
Jul 31, 2004 - 5:25 PM |
The ST Master Cylinder appears is sufficient. (There may in fact be no St-specific master cylinder, but I don't have a parts catalog in front of me.) This post has been edited by S_C_M: Jul 31, 2004 - 5:26 PM |
Aug 25, 2004 - 10:12 PM |
Enthusiast Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
Who here on the site has actually done the conversion??
Aug 26, 2004 - 9:18 AM |
yeah good question who has done this conversion. thanks man I should have asked that in the first place
Aug 26, 2004 - 10:29 AM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
I did it. It was quick and easy.
And NO, you don't need to get a new master cylinder. The ST will work fine. They use the same one, nothing is different. |
Aug 26, 2004 - 6:38 PM |
I am one of them... Straight bolt-on... assuming everything is still assembled... -------------------- "It's ok to be naked girl... I'm an artist!"
Aug 26, 2004 - 9:05 PM |
Enthusiast Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
ive got a gt that i will get rid of the brakes for really cheap. i just would need to be informed how too.
Aug 26, 2004 - 10:33 PM |
Sep 2, 2004 - 2:59 PM |
Enthusiast Joined Mar 18, '04 From San Diego Currently Offline Reputation: 0 (0%) |
what is the difference? by doing this what will you change? performance wise
Sep 2, 2004 - 8:20 PM |
Disc brakes look better... ;] Actually... overall braking performance will increase because disc brakes cool much faster than drums... although most people here do it for the sake of looks... -------------------- "It's ok to be naked girl... I'm an artist!"
Sep 2, 2004 - 8:23 PM |
most, but not all |
Sep 13, 2004 - 8:24 PM |
Enthusiast Joined Sep 18, '02 From Northern, Virginia Currently Offline Reputation: 0 (0%) |
so if you buy set of 4 rotors online then its for a gt, meaning if you have st and have done the rear disc conversion, you must do the front conversion to get all 4 of the rotors to fit?
Sep 13, 2004 - 10:19 PM |
you would need teh GT front calipers, (maybe)backing plate adn pads to go along with the rotors
Lo-Fi Version | Time is now: November 29th, 2024 - 6:29 AM |
